[mapguide-users] Regarding Linking of Layers with Map at run time
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat Feb 14 06:51:17 EST 2009
I can't guess what you are trying to achieve with the code.
MaestroAPI is not the only way, you can use the native API like you do,
but you have to handle all the quirks yourself, which is not a trivial task.
This line is not valid C#:
        MgResourceIdentifier webLayoutId = new
MgResourceIdentifier("Library:// Samples/ Sheboygan
/Layouts\BasicLayout.WebLayout");
\B is not a valid string escape sequence, and there seems to be some
spaces, which may come from the mail program.
I think you can get a better understanding of the MaestroAPI from these
two examples:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/AddInitialLayer
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/CustomizedZoomWithWebLayout
This piece of code seems to ovewrite the runtime map, with the Sheboygan:
        MgMap map = new MgMap();
        MgResourceIdentifier resId = new
MgResourceIdentifier("Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition");
        String mapName = resId.GetName();
        map.Create(resourceSrvc, resId, mapName);
        MgResourceIdentifier mapStateId = new
MgResourceIdentifier("Session:" + sessionId + "//" + mapName + "." +
MgResourceType.Map);
        map.Save(resourceSrvc, mapStateId);
This code seems to set the startup map in the library weblayout to the
sheboygan map:
        MgByteReader byteReader =
resourceSrvc.GetResourceContent(webLayoutId);
        XmlDocument doc = new XmlDocument();
        String xmlLayoutDef = byteReader.ToString();
        doc.LoadXml(xmlLayoutDef);
        XmlNode parentNode = doc.GetElementsByTagName("ResourceId").Item(0);
        if (parentNode != null)
            XmlNode mapRessource =
doc.SelectSingleNode("/WebLayout/Map/ResourceId");
            if (mapRessource != null)
                mapRessource.InnerText = "Library://Samples/Sheboygan/"
+ "Maps/Sheboygan" +
".MapDefinition";
                String string1= doc.DocumentElement.OuterXml;
                resourceSrvc.SetResource(webLayoutId, new
MgByteReader(string1, "text/xml"), null);
You cannot overwrite the runtime map, because the AJAX viewer always
overwrites the
runtime map at startup, so the first segment of code has no effect.
The last part seems correct, but the exception states that the xml is
broken in some way.
I have seen others complain about the same problem, but I don't know
what happens.
It seems that the SetResource or MgByteReader breaks the data in some way.
Regards, Kenneth Skovhede, GEOGRAF A/S
ravinder.singh at BIRLASOFT.COM skrev:
> I have written the following code also, it uses xml and infact when
> this code runs it runs perfectally without any problem, it does what I
> wanted to do, it changes the map definition  in web layout, and it
> runs perfectally if I run from maestro,  but when I try to run from my
> .net page
> <frame id="viewerFrame" frameborder="no" marginwidth="0"
> marginheight="0" scrolling="no"
> src="../mapviewernet/ajaxviewer.aspx?SESSION=<%=sessionId%>&WEBLAYOUT=<%=webLayout%>">
> Then the problem comes. And it says the following error.
> Type 'OSGeo.MapGuide.MgNullArgumentException' in Assembly
> 'MapGuideDotNetApi, Version=2.0.0.2716, Culture=neutral,
> PublicKeyToken=null' is not marked as serializable.
> If I save the map once in maestro then the viewer also runs. I have
> also tried to read the header of xml and passing in
> resourceSrvc.SetResource as third parameter, the problem remains the same.
> So I just want to confirm whether maestro API you suggested would be
> the final and last way to do this thing, or some other way ? Because I
> am not aware of using maestro api.
> //Here is my code
> MgUserInformation userInfo_new = new MgUserInformation(sessionId);
>         MgSiteConnection siteConnection = new MgSiteConnection();
>         siteConnection.Open(userInfo_new);
>         MgResourceService resourceSrvc =
> (MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
> "Library://Samples/Sheboygan/" + "Maps/Sheboygan" +
> ".MapDefinition";
> *Regards,*
> Ravinder
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Kenneth
> *Sent:* Saturday, February 14, 2009 4:33 PM
> *To:* MapGuide Users Mail List
> *Subject:* Re: [mapguide-users] Regarding Linking of Layers with Map
> at run time
> The MgMap class represents a runtime map, not a MapDefinition.
> There is no such class a a MgMapDefinition, so you have to read/write
> the xml.
> If you wish to use the standard viewer, you have to do this.
> I was very annoyed by this, so I created the MaestroAPI that has
> classes for all the Xml documents,
> including the MapDefinition:
> If you start the viewer with an empty map, you can access the MgMap
> object,
> and add layers as runtime layers, using the MgMap.Layers.Add method.
> ravinder.singh at BIRLASOFT.COM <mailto:ravinder.singh at BIRLASOFT.COM> skrev:
> Hi Stefan,
> I put the way you said but it gives the following error now.
> Type 'OSGeo.MapGuide.MgXmlParserException' in Assembly
> *Regards,*
> Ravinder Singh
> <mailto:mapguide-users-bounces at lists.osgeo.org>
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Stefan
> Dalakov
> *Sent:* Friday, February 13, 2009 11:10 PM
> at run time
> Try
> MgResourceIdentifier mapName = new MgResourceIdentifier("Session:" +
> sessionId + "//Sheboygan.MapDefinition");
> Stefan Dalakov
> ravinder.singh at BIRLASOFT.COM <mailto:ravinder.singh at BIRLASOFT.COM> wrote:
> Hi All,
> I have created the map definition in maestro and also created a web
> layout, and I have hundreds of Maps, and each map will have a single
> layer, but I don't want to create the hundreds of maps for each single
> layer. For that purpose I though I will just make a single map and
> will associate the layer at run time to that map. So I wrote the
> following set of code for Sheboygan sample
> But when I reach to map.Save(resourceSrvc, mapName)
> it gives me the error
> MgXmlParserException {"An exception occurred in the XML parser."}
> And also I tried with Map.Open and then the following error comes
> Resource was not found:
> Session:b275c3b6-ffff-ffff-8000-001a4bb4a756_en_7F0000010AFC0AFB0AFA//Samples/Sheboygan/Sheboygan.MapDefinition
> MgUserInformation userInfo = new MgUserInformation(defaultUser,
> defaultPassword);
>       MgSite site = new MgSite();
>       site.Open(userInfo);
>       sessionId = site.CreateSession();
> sessionId + "//Samples/Sheboygan/Sheboygan.MapDefinition");
>       map.Open(resourceSrvc, mapName); // Here the problem comes
>       map.Save(resourceSrvc, mapName); // Here the problem comes
> I am using .net aspx with map guide 2.0
> *Thanks & Regards,*
> Ravinder Singh
> "This message and any attachments are solely for the intended
> recipient and may contain Birlasoft confidential or privileged
> information. If you are not the intended recipient,any
> disclosure,copying, use, or distribution of the information included
> in this message and any attachments is
> prohibited. If you have received this communication in error, please
> notify us by reply e-mail at (administrator at birlasoft.com
> <mailto:administrator at birlasoft.com>) and permanently delete this
> message and any attachments. Thank you."
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org <mailto:mapguide-users at lists.osgeo.org>
> notify us by reply e-mail at (administrator at birlasoft.com) and
> permanently delete this message and any attachments. Thank you."
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090214/c21c4f84/attachment.html
