[mapguide-users] Fusion 2.0 Beta Notes
Paul Spencer pagameba at gmail.com
Tue Feb 17 07:52:53 EST 2009
Thanks for the feedback Mark, we'll try to take a look at these
issues.  Which template are you using, or is it one that you have
created?
Paul
On 16-Feb-09, at 9:17 PM, Mark Pendergraft wrote:
> I’m trying to implement Google Maps into my Fusion application using
> the 2.0 Beta.  I’m having a bit of trouble.  Right now I’m trying to
> load the Sheboygan map and the google map in the same MapGroup and
> my program has continuous errors (which seem to point to the
> maptip).  I also have to disable the OverviewMap when I load the
> google map because it crashes when it loads.
> Can anyone provide some instructions or a brief overview on how we
> should be incorporating MapGuide and Google Maps into the same map?
> Also, I’ve noticed a few other bugs in 2.0:
> The CursorPosition widget does not show up in default layout unless
> the widget is added twice to the Statusbar container.  It would
> appear that the second element in the statusbar container is
> actually overlapping the first element.  So the element is there,
> but you can’t see it because the second element in the container is
> on top of it.   This happens with all Splitterbar controls added to
> the layout.
> Neither Tooltips nor the MapTip appear to work.
> The Coordinates in the CursorPosition widget appear to be
> incorrect.  The X value is always negative (on the Sheboygan example
> and on my own map which is in Washington State Plane Coordinate
> System (HPGN) North Zone US Foot).  A negative X value in a
> Washington state projection would indicate a position somewhere in
> the ocean.
> Another issue I’ve noticed with the CursorPosition widget is that it
> always seems to report in meters despite my map being in Feet.  The
> widget reports in my maps units (feet), but appends a ‘m’ on the end
> of the X and Y.
> Thanks
> -Mark P.s
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
