[mapguide-users] Create programmatically a map
sekko970 sekko970 at virgilio.it
Wed Feb 18 09:19:32 EST 2009
Each try is failed for the following error: 'Invalid resource type'.
Dim resID As New MgResourceIdentifier("Librarry://.../" & MyLayout & "." &
MgResourceType.WebLayout)
Dim enc As New System.Text.UTF8Encoding(False)
Dim newLayoutDef As New MgByteSource(enc.GetBytes(newLayoutXML.OuterXml),
enc.GetByteCount(newLayoutXML.OuterXml))
newLayoutDef.SetMimeType(MgMimeType.Xml)
resourceSrvc.SetResource(resID, newLayoutDef.GetReader(), Nothing)
map.Save(resourceSrvc)
resourceSrvc.UpdateRepository(resID, newLayoutDef.GetReader(), Nothing)
Ivan Milicevic wrote:
> I'm guessing that you must update repository after creating new layout.
> Look at
> http://mapguide.osgeo.org/files/mapguide/docs/2.0/d8/de1/class_mg_resour
> ce_service_e0294dc308ecc4708b79d493086f210b.htm
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sekko970
> Sent: Wednesday, February 18, 2009 2:01 PM
> To: mapguide-users at lists.osgeo.org
> Subject: RE: [mapguide-users] Create programmatically a map
> Sure, this is the related record in error log:
> <2009-02-18T12:07:11> 			Administrator
>  Error: Resource was not found:
> Session:36fb9200-0000-1000-8000-000bcd727323_en_7F0000010AFC0AFB0AFA//ne
> w.Map
>  StackTrace:
>   - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
> \resource\ResourceServiceHandler.cpp
>   - MgOpGetResourceData.Execute line 124 file
> \resource\OpGetResourceData.cpp
>   - MgServerResourceService.GetResourceData line 1401 file
> \resource\ServerResourceService.cpp
>   - MgApplicationRepositoryManager.GetResourceData line 1201 file
> \resource\ApplicationRepositoryManager.cpp
>   - MgResourceContentManager.GetDocument line 590 file
> \resource\ResourceContentManager.cpp
>   - MgResourceDefinitionManager.GetDocument line 476 file
> \resource\ResourceDefinitionManager.cpp
> w.Map
>> Very interesting... Can you check mapguide error log? Is there any
>> records related with this problem?
>> Sent: Wednesday, February 18, 2009 12:41 PM
>> Below you can see the new map and layout XML created from
>> http://localhost/mapguide/mapagent/index.html before and after the
>> saving
>> from Maestro (is equals for both).
>>   <?xml version="1.0" encoding="UTF-8" ?>
>> - <ResourceList xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xsi:noNamespaceSchemaLocation="ResourceList-1.0.0.xsd">
>> - <ResourceDocument>
>>   <ResourceId>Library://.../newMap.MapDefinition</ResourceId>
>>   <Depth>3</Depth>
>>   <Owner>Administrator</Owner>
>>   <CreatedDate>2009-02-18T11:31:29Z</CreatedDate>
>>   <ModifiedDate>2009-02-18T11:31:29Z</ModifiedDate>
>> - <ResourceDocumentHeader
>> xsi:noNamespaceSchemaLocation="ResourceDocumentHeader-1.0.0.xsd">
>> - <Security
> xsi:noNamespaceSchemaLocation="ResourceSecurity-1.0.0.xsd">
>>   <Inherited>true</Inherited>
>> - <Groups>
>> - <Group>
>>   <Name>Everyone</Name>
>>   <Permissions>r,w</Permissions>
>>   </Group>
>>   </Groups>
>>   </Security>
>>   </ResourceDocumentHeader>
>>   </ResourceDocument>
>>   </ResourceList>
>>   <ResourceId>Library://.../newLayout.WebLayout</ResourceId>
>>   <Depth>3</Depth>
>>   <CreatedDate>2009-02-18T11:35:51Z</CreatedDate>
>>   <ModifiedDate>2009-02-18T11:36:32Z</ModifiedDate>
>> - <Security
>> - <Groups>
>> - <Group>
>>   </Group>
>>   </Groups>
>>   </Security>
>>   </ResourceDocument>
>>   </ResourceList>
>>> Please, before you open layout and map in Maestro go to:
>>> http://localhost/mapguide/mapagent/index.html -> go to
>>> Resource-->GetResourceContent--> and type correct resource ID on
> right
>>> side. See is there any strange things in output XML file. Compare it
>>> after saving it in Maestro.
>>> Sent: Wednesday, February 18, 2009 12:05 PM
>>> This is my problem:
>>> I have created programmatically a map (and its layout) using MG .Net
>> web
>>> API.
>>> After creation, the new map and layout are visible in MG Maestro, and
>>> using
>>> the 'Show in browser" button are correctly shown in browser.
>>> The problem happens when I load the map directly from browser, and
> the
>>> following error appears:
>>> << The type 'OSGeo.MapGuide.MgNullArgumentException' in assembly
>>> 'MapGuideDotNetApi, Version= 2.0.2.30 11, Culture=neutral,
>>> PublicKeyToken=null' is not marked as serializable >>.
>>> Then, simply saving the new layout from MG Maestro (without any
>>> modification), and reloading the map directly from browser, the error
>>> disappears and the map is correctly shown.
>>> After saving the layout, there aren't differences in map and layout
>> XML
>>> definitions.
>>> Have you any idea about?
>>>> Can you write pseudo code of your task? What do you want to do? I
>> need
>>>> little more information about your problem.
> sekko970
>>>> Sent: Wednesday, February 18, 2009 11:42 AM
>>>> Hi Ivan,
>>>> below, you can see my code to create the new map:
>>>> Dim resID As New
>>>> MgResourceIdentifier(Library://.../maps/MyMap.MapDefinition)
>>>> Dim newMapDef As New
>>> MgByteSource(enc.GetBytes(XMLMapTemplate.OuterXml),
>>>> enc.GetByteCount(XMLMapTemplate.OuterXml))
>>>> newMapDef.SetMimeType(MgMimeType.Xml)
>>>> Dim resourceSrvc As MgResourceService =
>>>> siteConn.CreateService(MgServiceType.ResourceService)
>>>> resourceSrvc.SetResource(resID, newMapDef.GetReader(), Nothing)
>>>> Dim map As New MgMap()
>>>> map.Create(resourceSrvc, resID, MapName)
>>>> Then, this is my code to create the map layout:
>>>> Dim resID As New
>>>> MgResourceIdentifier(Library://.../Layouts/MyMap.WebLayout)
>>>> MgByteSource(enc.GetBytes(XMLLayoutTemplate.OuterXml),
>>>> enc.GetByteCount(XMLLayoutTemplate.OuterXml))
>>>> Perhaps between map and layout creation I should refresh the
> mapframe
>>> as
>>>> suggested from you?
>>>> Thanks in advance for your help.
>>>> Fabio
>>>>> Can you provide us code sample?
>> sekko970
>>>>> Sent: Wednesday, February 18, 2009 10:38 AM
>>>>> Hi Ivan,
>>>>> thanks for your suggestion, but my problem is not to refresh the
>>>> viewer
>>>>> to
>>>>> show the map just created, but is the correct creation of new map
>> and
>>>>> layout.
>>>>> I think to have found the origin of my problem, but I don't
>>> understand
>>>>> the
>>>>> error:
>>>>> Argument is null. Exception occurred in method
>>>>> MgWebLayout.ParsePrintCommand
>>>>> at line 880 in file
> c:\build_bond_area\bond_nightly\build_41.3\ent\os\web\src\webapp\WebLayo
>>>>> ut.cpp
>>>>> Have you some idea?
>>>>> Thanks, Fabio
>>>>>> Hello,
>>>>>> You can change href of mapFrame. Here is sample code.
>>>>>> var mapa = "cijevi"; //defines map name
>>>>>> var stringMape = "Library%3a%2f%2fPROJEKTI%2fSUPRANET%2fMAPE%2f" +
>>>>> mapa;
>>>>>> var hrefMapa =
> "http://172.21.10.3/mapguide/mapviewernet/mapframe.aspx?MAPDEFINITION="
>>>>>> + stringMape +
> ".MapDefinition&amp;TYPE=HTML&amp;SHOWLEGEND=0&amp;SHOWPROP=0&amp;INFOWI
> DTH=0&amp;LOCALE=en&amp;HLTGT=1&amp;HLTGTNAME=&amp;SHOWSLIDER=0&amp;SESS
>>>>>> ION=" + mgSessionId + ";
>>>>>> //changing mapFrame href
>>>>>> mapFrame.location.href = hrefMapa;
>>>>>> Hope this helps.
>>> sekko970
>>>>>> Sent: Wednesday, February 18, 2009 9:57 AM
>>>>>> Subject: Re: [mapguide-users] Create programmatically a map
>>>>>> Hi Kenneth,
>>>>>> I need again your help about my problem.
>>>>>> I think the problem is that after new map run-time creation in
>>>> library
>>>>>> repository, I cannot use its map definition to create its web
>>> layout.
>>>>>> How can I assign the new map to the layout?
>>>>>> Thanks again, Fabio
>>>>>> Kenneth Skovhede, GEOGRAF A/S wrote:
>>>>>>> Try to look at the Maestro code:
> http://trac.osgeo.org/mapguide/browser/trunk/Tools/Maestro/MaestroAPI/Lo
>>>>>> calNativeConnection.cs#L182
>>>>>>> Hopefully you will find a small difference there.
>>>>>>> Regards, Kenneth Skovhede, GEOGRAF A/S
>>>>>>> sekko970 skrev:
>>>>>>>> Yes, the "OuterXml" property contains the XML header line.
>>>>>>>> Fabio
>>>>>>>>> Does the "OuterXml" property contain the <? version="1.0"
>>>>>>>>> encoding="utf-8" standalone="true" ?> line?
>>>>>>>>> sekko970 skrev:
>>>>>>>>>> Hi Kenneth, and thanks for your promptly reply.
>>>>>>>>>> I had used an ancoding instance.
>>>>>>>>>> Below, you can see my code to create the new map:
>>>>>>>>>> Dim resID As New
> Nothing)
>>>>>>>>>> Dim resID As New
>>>> Nothing)
>>>>>>>>>> Thanks for your help.
>>>>>>>>>> Fabio
>>>>>>>>>>> You could have the problem that .Net emits an utf-8
>>>>>> byte-order-marker
>>>>>>>>>>> (BOM), when
>>>>>>>>>>> writing xml.
>>>>>>>>>>> http://en.wikipedia.org/wiki/Byte-order_mark
>>>>>>>>>>> To counter this, explicitly create an encoding instance:
>>>>>>>>>>> System.Text.Encoding enc = new
>> System.Text.UTF8Encoding(false);
>>>>>>>>>>> Then implement a xml writer, or manually convert the xml to
>>>>> bytes,
>>>>>>>>>>> using
>>>>>>>>>>> the encoding.
>>>>>>>>>>> FYI, the MaestroAPI is LGPL, and so you may use it as a
>>> library,
>>>>>> even
>>>>>>>>>>> for commercial applications,
>>>>>>>>>>> and it handles this quirk and others.
>>>>>>>>>>> sekko970 skrev:
>>>>>>>>>>>> Dear all,
>>> MG
>>>>>> .Net
>>>>>>>>>>>> web
>>>>>>>>>>>> API.
>>>>> Maestro,
>>>>>> and
>>>>>>>>>>>> using
>> browser,
>>>>>> and
>>>>>>>>>>>> the
>>>> assembly
>>> any
>>> the
>>>>>> error
>>>>>> layout
>>>>>>>>>>>> XML
>>>>>>>>>>>> definitions.
>>>>>>>>>>>> Thank you in advance.
>>>>>>>>>>>> Fabio
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> mapguide-users mailing list
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>>>>> View this message in context:
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345737.htm
>>>>>> l
>>>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2345874.htm
>>>>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346122.htm
>>>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346216.htm
>>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346367.htm
>> l
> http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2346704.htm
> l
View this message in context: http://n2.nabble.com/Create-programmatically-a-map-tp2314238p2347057.html
