[mapguide-users] Source Code for GT - Test Application
Andy Morsell amorsell at spatialgis.com
Wed Feb 18 14:02:46 EST 2009
I think you also need the Redding.mgp package that has the invoke URL's
already setup in the main web layout.  You can download it here:
http://www.spatialgis.com/Redding.mgp
Also, here is a readme file that I dug up:
In order to setup the application, you will need to:
 1. extract the gt.zip file in the www folder
 2. check the gtcontants.php file to validate the server path(s)
 3. load the Redding.mgp package
 4. create a user called Markup (password: markup) that has authoring
priviledges
 	OR
    create your own user with an Author role and edit the source code
accordingly
 5. the generic task commands are invoke URL calls
Andy
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Steve G
Sent: Wednesday, February 18, 2009 10:48 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Source Code for GT - Test Application
Thanks a bunch.
Any quick instructions on where to install and what files to install if I am
just considering the shared markup tool?  I am assuming just install in a
folder in C:\Program Files\MapGuideOpenSource2.0\WebServerExtensions\www and
create an invoke URL (will perhaps need some additional code changes).
I am testing with the shared markup tool and the Scribble tool for different
types of options for marking up the maps for my users.  I've got the
scribble tool going and works pretty well.  Learning more as I go.
I really appreciate all the help from the forum members.  If there are
changes to the code for this tool (that I can figure out), I'll try to post
back to the forum.
Andy Morsell wrote:
> I'm not sure where the source code disappeared to from the sample site
> either..... You can download a copy of GT from here:
> http://www.spatialgis.com/gt.zip
> I am unsure of the state of this code as it pertains to full compatibility
> with the current version of MGOS (meaning there have been some API changes
> but may not affect the code).  This zip file does, however, contain some
> fixes for bugs that I found a couple of years ago.
> Andy Morsell, P.E.
> Spatial Integrators, Inc.
> www.SpatialGIS.com
> From: mapguide-users-bounces at lists.osgeo.org
> Sent: Tuesday, February 17, 2009 6:31 PM
> Subject: Re: [mapguide-users] Source Code for GT - Test Application
> Sorry, just bumping this item up.  I would think that someone out there
> knows
> where the source code is or has it saved somewhere.  Maybe I should post
> on
> the Autodesk forum?
> Any help would be much appreciated...
> Steve G wrote:
>> I've been looking for the source code for the GT - Test Application:
>> data.mapguide.com/mapguide/gt/index.php
>> Specifically, I am looking for the shareable markups source code.  I
>> think
>> the code was previously on the website for download, but I can't find a
>> link to it anywhere...maybe I'm blind?  Sorry, if this was previously
>> posted, but I looked through the forum and I couldn't find any relevant
>> messages.
>> Thanks.
http://n2.nabble.com/Source-Code-for-GT---Test-Application-tp2305046p2344628
> .html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://n2.nabble.com/Source-Code-for-GT---Test-Application-tp2305046p2348655
.html
