[mapguide-users] Impossible To connect trougth ODBC to .csv
Dave Wilson dave.wilson at autodesk.com
Fri Feb 20 13:48:06 EST 2009
As mentioned in an earlier thread there is a bug on this and even though you might be able to make the feature source your layer will fail to preview.
It looks like the bug is an issue with the file lookup. FDO has mapped the "table" name to the file name but instead of the period substituted an underscore so when sending the request to the provider it appears to be looking for filename_csv for the table name instead of filename.csv which is what the ODBC DSN is expecting.
Bottom line is it doesn't work.
Dave
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Micho Gar
Sent: Friday, February 20, 2009 2:25 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Impossible To connect trougth ODBC to .csv
Hi all,
After many attempts I have not been able to connect to a file .csv. Do you know if you can connect somehow to a text file?.
Greetings and thanks
# michogar
# Analista Programador SIG
# Ubuntu Linux Counter 462666
"Cuenta una leyenda que si reproduces un DVD de Windows Vista original al revés se oye a Bill Gates entonando cantos satánicos... Pero eso no es lo peor... Si lo reproduces del derecho... ¡Se instala!."
"It has a legend that if you play an original Windows Vista DVD backwards to hear Bill Gates Satanic chanting songs ... But that's not the worst ... If you play it right ... It installs!.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090220/d26703a8/attachment.html
