[mapguide-users] Silverlight/Moonlight Viewer
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Sat Feb 21 05:26:30 EST 2009
I was the one who originally started the thread, and I have not
done anything in that direction yet.
You may want to look at the DeepEarth Silverlight application:
http://www.codeplex.com/deepearth
It basically uses the DeepZoom feature of Silverlight together with tiles
from Virtual Earth. It should be very easy to modify it to use MapGuide
tiles
instead.
You still need to manually build selection/tooltip/overlays though.
Regards, Kenneth Skovhede, GEOGRAF A/S
Carl Jokl skrev:
> The viewer and the performence of it has continued to be an issue for us. We
> were backed into a situation where we had to continue using the DWF viewer
> because it was the only viewer capable of delivering the application we
> develop at a usable level of performance on MapGuide 2009. I myself am not
> at liberty to make decisions as to what I am assigned to work on. If there
> was work being done on a new viewer in the community it would not be
> unreasonable for our organisation to help in the development if it
> potentially made the difference between being able to migrate from Mapguide
> 6.5 to 2009. If the new viewer is just an idea which was never developed
> then at least I know what became of that. I suspect that the viewer is
> probably just going to be one of a number of issues which would need to be
> overcome in order to make MapGuide 2009 workable for the project we are
> trying to use it for.
