[mapguide-users] Connect to MS SQL Server
Jason Birch Jason.Birch at nanaimo.ca
Mon Feb 23 11:42:30 EST 2009
The SQL Server 2005 provider that comes with Map 3D is proprietary, and
not available in MapGuide Open Source.  If you want to display this data
you will need to use MapGuide Enterprise.
If it's an option, I would suggest using the open source SQL Server 2008
provider.
Jason
-----Original Message-----
To: MapGuide Users Mail List
Subject: [mapguide-users] Connect to MS SQL Server
I have installed MS SQL Server Express Edition 2005 and have some tables
there, created by Map3D 2009, containing lines and points.
Which provider should I use to connect to this data as ODBC provider
allows only point features?
