[mapguide-users] Fatal Parse error on SetResource
Peter Filip reklamama at centrum.sk
Tue Feb 24 08:47:02 EST 2009
I followed your advice but i get still the same error.
I saved the XML file as UTF-8 without BOM
and i also changed the code
        XmlDocument layerDefinition = new XmlDocument();
layerDefinition.Load(System.Web.HttpContext.Current.Server.MapPath(@"xml/layer.xml"));
        UTF8Encoding enc = new UTF8Encoding(false);
        Byte[] byteDef = enc.GetBytes(layerDefinition.ToString());
        MgByteSource bs = new MgByteSource(byteDef, byteDef.Length);
        bs.SetMimeType(MgMimeType.Xml);
        MgResourceIdentifier layerId = new MgResourceIdentifier("Session:" +
mgSessionId + @"//cinnost." + MgResourceType.LayerDefinition);
        resourceService.SetResource(layerId, bs.GetReader(), null);
Kenneth Skovhede, GEOGRAF A/S wrote:
> MapGuide only accepts utf-8 encoded data, with no BOM.
> You must create an encoder for utf-8, and set the BOM generation to false.
> With this encoder, you can get the bytes in the correct format.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> Peter Filip skrev:
>> Hello,
>> i want to create a new layer and save it in the session repository.
>> I use this code:
>> layerDefinition.Load(System.Web.HttpContext.Current.Server.MapPath(@"xml/Roads.xml"));
>>         Byte[] byteDef =
>> System.Text.Encoding.Default.GetBytes(layerDefinition.ToString());
>>         MgLayer layer = new MgLayer(layerId, resourceService);
>> Error show up on this line
>> And here is the error message
>>      An exception occurred in DB XML component.
>>         Error: XML Indexer: Fatal Parse error in document at line, 1,
>> char
>> 1. Parser message: Invalid document structure
>> The XML LayerDefinition should be OK. I used the one from Sheyboygan
>> package.
>> I have no idea where's the catch.. Any suggestions??
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Fatal-Parse-error-on-SetResource-tp2377337p2377995.html
