[mapguide-users] GetFeaturesKml and GetLayerKml
Rodolfo Moreno rmoreno at voxiva.com
Tue Feb 24 19:01:39 EST 2009
Hi alucas,
did you get use the GetLayerKml for generating KML. I have not had succesful
with it.
This is my code:
String s_basePath = Request.ServerVariables["APPL_PHYSICAL_PATH"];
        MapGuideApi.MgInitializeWebTier(s_basePath + "../webconfig.ini");
        MgSiteConnection siteConnection = new MgSiteConnection();
        siteConnection.Open(new MgUserInformation("Administrator",
"admin"));
        MgKmlService kmlService =
(MgKmlService)siteConnection.CreateService(MgServiceType.KmlService);
        MgResourceService resService =
(MgResourceService)siteConnection.CreateService(MgServiceType.ResourceService);
        MgFeatureService featService =
(MgFeatureService)siteConnection.CreateService(MgServiceType.FeatureService);
        MgLayer layer = new MgLayer(new
MgResourceIdentifier("Library://xxx.FeatureSource"), resService);
        MgSpatialContextReader contexts1 =
featService.GetSpatialContexts(new
MgResourceIdentifier("Library:xxx.FeatureSource"), true);
        contexts1.ReadNext();
        MgByteReader byteReader = contexts1.GetExtent();
        MgAgfReaderWriter agfReaderWriter = new MgAgfReaderWriter();
        MgGeometry geometry = agfReaderWriter.Read(byteReader);
        MgEnvelope env = geometry.Envelope();
        String mapagentURI =
"http://localhost/mapguide/mapagent/mapagent.fcgi";
        MgByteReader byteReader1 = kmlService.GetLayerKml(layer, env, 796,
717, 96, 0, mapagentURI, MgMimeType.Xml);
        XmlDocument doc = new XmlDocument();
        doc.LoadXml(byteReader1.ToString()); // The error is raised in this
line
        Response.ContentType = "application/vnd.google-earth.kml+xml";
        Response.Write( doc );
The error is raised in the line:
  ERROR: Invalid mime type: application/vnd.google-earth.kml+xml
any help will be very appreciated, thanks
alucas-3 wrote:
> Hi Jason,
> It seems that with the GetFeaturesKML() method there is no dependency from
> the server session. If I generate the .kml with this method the file size
> is in my example about 4 MB. So, it seems that the features are in the kml
> and not connected vía mapagent and session.
> If you want some sample code I can send you how it works.
> Regards,
> JasonBirch wrote:
>> Hi,
>> Absolutely you can, it's just that the original RFC intended these as
>> interactive APIs created from the initial GetMapKML rather than
>> individual layer/feature access APIs.  I don't think there's any problem
>> with it, but haven't seen a lot of experimentation either...
>> That would be the approach that I'd take as well if I was going to try
>> using the build-in functions; DMSG wrote something similar to that for
>> me that basically reads an existing layer definition, uses a bit of DOM
>> manipulation to swap out the filter element's text, and uses the
>> modified layerdefinition in a new map.  GetLayerKML should allow a
>> similar strategy; please let us know how you make out.
>> Good luck!
>> Jason
>> -----Original Message-----
>> From: mapguide-users-bounces at lists.osgeo.org
>> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of alucas
>> Sent: Thursday, November 13, 2008 00:23
>> To: mapguide-users at lists.osgeo.org
>> Subject: RE: [mapguide-users] GetFeaturesKml and GetLayerKml
>> Hi Jason,
>> Actually, I can use this operations calling directly the agent as well
>> from
>> the web extensions API (i.e Java) from the MgKmlService. For my current
>> project, I need to publish one entire layer and some features from this
>> layer. For now, publish the layer via MgKmlService::GetLayerKml(...)
>> works
>> fine. Otherwise, GetFeaturesKml(...) does not work for me or it does the
>> same that GetLayerKml.
>> So, my next step is create a filter for the layer and then call
>> GetLayerKml
>> in order to see if it only export the filtered features.
>> P.D: Sorry for my english.
>> Thanks.
>> JasonBirch wrote:
>>> These functions aren't actually supposed to be called directly be the
>>> user.
>>> http://trac.osgeo.org/mapguide/wiki/MapGuideRfc4
>>> There are quite a few other limitations here, such as being
>>> session-based (if the user saves in Google Earth, it'll break when the
>>> session expires), etc.
>>> I'd personally recommend hand-coding the KML that you emit.  There is
>> a
>>> sample app here with source included that shows how to do this:
>>> http://data.mapguide.com/mapguide/DynamicKml/GoogleEarth.php
>>> Jason
>>> From: alucas
>>> Subject: [mapguide-users] GetFeaturesKml and GetLayerKml
>>> What is the diference between these methods? How can I get only some
>>> features from my layer and then export to kml? I suposed that with
>>> GetFeaturesKml I was able to filter features in a layer...
>>> mapguide-users mailing list
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> View this message in context:
>> http://www.nabble.com/GetFeaturesKml-and-GetLayerKml-tp20459874p20476499
>> .html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/GetFeaturesKml-and-GetLayerKml-tp1818790p2381181.html
