[mapguide-users] Source Code for GT - Test Application
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Feb 25 02:34:43 EST 2009
Something was changed in the way MapGuide handles coordinate systems.
Search the nabble fourm, I have seen the solution presented on the list
at least 3 times :).
Regards, Kenneth Skovhede, GEOGRAF A/S
Steve G skrev:
> Any help with this error?  Is this something that can be fixed or does it
> relate to the version of MG that I am using?  I am using MG 2.0.2.3011.
> Thanks for the help.
> Steve G wrote:
>> I got the Markup tool started.  I was able to create a new markup, but
>> when I go to edit the markup, I get the following error when trying to
>> place any element on the map (point, line, polygon, etc).
>> Argument is null.
>> Argument is null. Exception occurred in method MgCoordinateSystemCache.Get
>> at line 120 in file
>> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\geometry\CoordinateSystem/CoordinateSystemCache.cpp
>> Any suggestions on how to fix this?
>> djonio wrote:
>>> Steve G,
>>> Glad to hear that you got Scribble working.
>>> I do mention this point in the comments but just in case you missed it.
>>> The Scribble markup code is really a knock-off of "gt". I has been some
>>> time since it was written and my memory is not so good but I think I only
>>> added the code for circles and I think they are just a couple arcs ...
>>> I think "gt" has code for Themes and such but I never got around to that.
>>> It would be nice if someone coded that up.
>>> r,
>>> dennis
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090225/dd4512fa/attachment.html
