[mapguide-users] Weblayouts Buil-in commands
Rui Daniro ruidaniro at hotmail.co.uk
Wed Feb 25 07:09:12 EST 2009
Hi Kenneth,
I meant alter functionality. You said I can look in the "ajaxmappane.templ"
file and modify the javascript there, so where I can find that file?
De: Kenneth Skovhede, GEOGRAF A/S (via Nabble)
[mailto:ml-user+64672-1645459268 at n2.nabble.com]
Enviada: 25 February 2009 11:54
Para: Rui Daniro
Assunto: Re: [mapguide-users] Weblayouts Buil-in commands
That depends on what you mean by "edit/customize".
If you mean "change the text" (eg, translate), you can do so with
MapGuide Maestro, or you can manually modify the underlying xml.
If you mean "alter functionality", you can look in the
"ajaxmappane.templ" file and modify the javascript there.
Regards, Kenneth Skovhede, GEOGRAF A/S
Rui Daniro skrev:
> Hi all,
> I am usig MGE 2009 and I would like to know if it is possible
> built-in commands. If yes, where and how can I get the code.
> Thanks in advance.
> Rui
mapguide-users mailing list
mapguide-users at ...
This email is a reply to your post @
You can reply by email or by visting the link above.
View this message in context: http://n2.nabble.com/Weblayouts-Buil-in-commands-tp2383047p2383356.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090225/160385e8/attachment.html
