[mapguide-users] Mapguide on a CD ?
Jamo adam.jamison at portbris.com.au
Thu Jan 8 21:53:43 EST 2009
I am looking at running from within windows....
By live cd on ubuntu that would require the system to boot up from cd using
ubuntu ?
I have nothing against ubuntu or linux but I'm already stretching my
friendship with our it department... They will not allow various OS to load
on any of our pcs...
zspitzer wrote:
> there is already a mapguide live cd with 2.0.1 on ubuntu
> http://mapguide.osgeo.org/node/127
> z
> On Fri, Jan 9, 2009 at 1:35 PM, Jamo <adam.jamison at portbris.com.au> wrote:
>> Just Curious at the moment, I'm looking at ways of giving users the
>> ability
>> to use mapguide from a CD ?
>> It would have to run under Windows not a live boot .....
>> I've found This information which sort of helps....? has anyone tried
>> this
>> before?
>> http://www.wellho.co.uk/solutions/general-windows-running-apache-and-mysql-from-a-cd.html
>> I would settle for a USB Flash drive that can read / write data...
>> I'm guessing I need to change some variables in the serverconfig.ini and
>> httpd.conf(Anyone know what I might need to change) ? I've also seen some
>> mods to the apache server that allow ASP .Net to run under it :) This
>> will
>> make things a little easier as I've been writting in ASP .Net thus far :)
>> Basically thinking about field reports and the like, I'd like to be able
>> to
>> load a series of SDFs onto a flash drive and let the user go out in the
>> field with a gps unit, find where they are and see there location in
>> mapguide (basically trying to keep the interface the user is using the
>> same
>> throughout rather than bring in tons of different apps), create some
>> forms
>> that the user can edit data in the SDF then when they come back batch
>> update
>> the information that has been changed :) ....
>> This is a long way away but knowing it's possible is always good to keep
>> in
>> the back of my head ....
>> View this message in context:
>> http://n2.nabble.com/Mapguide-on-a-CD---tp2131494p2131494.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/Mapguide-on-a-CD---tp2131494p2131537.html
