[mapguide-users] Adding a temporary Layer in MapGuide
Arnaud De Groof Arnaud.DeGroof at spacebel.be
Mon Jan 12 09:21:09 EST 2009
The last code is enough.
My first code included only the step 3 and 4.
Regards
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Carmelo
Saffioti
Sent: lundi 12 janvier 2009 12:24
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Adding a temporary Layer in MapGuide
Thank you Arnaud for your reply!
You said: "Please find an example of code for the different steps". What
do you mean?
The code you posted is not enough?
If it's not enough, which of the following steps can I do with that
code?
1. Create a temporary FeatureSource for an SDF
2. Insert data into the temporary FeatureSource
3. Create a temporary LayerDefinition that points to the temporary
FeatureSource
4. Insert the temporary layer into the runtime map
5. Refresh the map
Thank you very much again for your help
Cheers
Carmelo
	----- Original Message -----
	From: Arnaud De Groof <mailto:Arnaud.DeGroof at spacebel.be>
<mailto:mapguide-users at lists.osgeo.org>
	Sent: Friday, January 09, 2009 9:37 AM
	Subject: RE: [mapguide-users] Adding a temporary Layer in
MapGuide
	Please find an example of code for the different steps:
	<?php
	include "../../mapviewerphp/constants.php";
	include "../../mapviewerphp/common.php";
	//include 'common.php';
	//include 'constants.php';
	$args = ($_SERVER['REQUEST_METHOD'] == "POST") ? $_POST : $_GET;
	$sessionId = $args['SESSION'];
	$mapName = $args['MAPNAME'];
	    $locale = "en";
	    $dataName = "test";
	    $popup = 0;
	    $lcolor = "0000ff";
	    $ffcolor = "ff0000";
	    $fbcolor = "ffffff";
	    $transparent = 0;
	    $distance = 0;
	    $units = "Points";
	    $linestyle = "Solid";
	    $fillstyle = "Solid";
	    $thickness = 1;
	    $merge = 0;
	    $foretrans = 50;
	    $srs = "";
	    $featureName = "Z";
	    $params = null;
	    //SetLocalizedFilesPath(GetLocalizationPath());
	    $dataSource = "Session:" . $sessionId . "//" . $dataName .
".FeatureSource";
	    $layerDef = "Session:" . $sessionId . "//" . $dataName .
".LayerDefinition";
	        InitializeWebTier();
	        $cred = new MgUserInformation($sessionId);
	        $cred->SetClientIp(GetClientIp());
	        $cred->SetClientAgent(GetClientAgent());
	        //connect to the site and get a feature service and a
resource service instances
	        $site = new MgSiteConnection();
	        $site->Open($cred);
	        $featureSrvc =
$site->CreateService(MgServiceType::FeatureService);
	        $resourceSrvc =
$site->CreateService(MgServiceType::ResourceService);
	        $dataSourceId = new MgResourceIdentifier($dataSource);
	        $layerDefId = new MgResourceIdentifier($layerDef);
	        //load the map runtime state
	        $map = new MgMap();
	        $map->Open($resourceSrvc, $mapName);
	        //locate the buffer layer in the map. It might or might
not already exist
	        $layers = $map->GetLayers();
	        // Get the map SRS
	        $srsFactory = new MgCoordinateSystemFactory();
	        $srsDefMap = GetMapSRS($map);
	        $mapSrsUnits = "";
	        $srsMap = $srsFactory->Create($srsDefMap);
	        $arbitraryMapSrs = $srsMap->GetType() ==
MgCoordinateSystemType::Arbitrary;
	        if($arbitraryMapSrs)
	            $mapSrsUnits = $srsMap->GetUnits();
	        //Create/Modify layer definition
	        $layerDefContent = BuildLayerDefinitionContent();
	        $resourceSrvc->SetResource($layerDefId,
$layerDefContent, null);
	            $classDef = new MgClassDefinition();
	            $classDef->SetName($featureName);
$classDef->SetDescription(GetLocalizedString("DATACLASSDESCR",
$locale));
	            $classDef->SetDefaultGeometryPropertyName("GEOM");
	            //Set KEY property
	            $prop = new MgDataPropertyDefinition("KEY");
	            $prop->SetDataType(MgPropertyType::Int32);
	            $prop->SetAutoGeneration(true);
	            $prop->SetReadOnly(true);
	            $classDef->GetIdentityProperties()->Add($prop);
	            $classDef->GetProperties()->Add($prop);
	            //Set ID property.
	            $prop = new MgDataPropertyDefinition("ID");
	            //Set geometry property
	            $prop = new MgGeometricPropertyDefinition("GEOM");
////$prop->SetGeometryTypes(MgFeatureGeometricType::mfgtSurface); //TODO
use the constant when exposed
	            $prop->SetGeometryTypes(4);
	            //Create the schema
	            $schema = new MgFeatureSchema("DataSchema",
GetLocalizedString("DATASCHEMADESCR", $locale));
	            $schema->GetClasses()->Add($classDef);
	            //finally, creation of the feature source
	            $sdfParams = new MgCreateSdfParams("LatLong",
$srsDefMap, $schema);
	            $featureSrvc->CreateFeatureSource($dataSourceId,
$sdfParams);
	            //Add layer to map
	            $layer = new MgLayer($layerDefId, $resourceSrvc);
	            $layer->SetName($dataName);
	            $layer->SetLegendLabel($dataName);
	            $layer->SetDisplayInLegend(true);
	            $layer->SetSelectable(true);
	            $layers->Insert(0, $layer);
	            $fsResourceId = new
	            $fsReader =
$resourceSrvc->GetResourceContent($fsResourceId);
	            $fsXml = $fsReader->ToString();
	            $fsDomDoc = DOMDocument::loadXML($fsXml);
	            $ldResourceId = new MgResourceIdentifier($layerDef);
	            $ldReader =
$resourceSrvc->GetResourceContent($ldResourceId);
	            $ldXml = $ldReader->ToString();
	            $ldDomDoc = DOMDocument::loadXML($lddXml);
	// Read the web layout into an XML DOM document object.
	$md = "Library://Test/X.MapDefinition";
	$mdResourceId = new MgResourceIdentifier($md);
	$mdReader = $resourceSrvc->GetResourceContent($mdResourceId);
	$mdXml = $mdReader->ToString();
	$mdDomDoc = DOMDocument::loadXML($mdXml);
	// Create the MapLayer XML nodeset in the first position
	$targetNode =
$mdDomDoc->getElementsByTagName("MapLayer")->item(0);
	$newNode = $targetNode->parentNode->insertBefore(new
DOMElement("MapLayer"), $targetNode);
	$newNode->appendChild($mdDomDoc->createElement("Name",
$dataName));
	$newNode->appendChild($mdDomDoc->createElement("ResourceId",
$layerDef));
	$newNode->appendChild($mdDomDoc->createElement("Selectable",
"false"));
	$newNode->appendChild($mdDomDoc->createElement("ShowInLegend",
"false"));
	$newNode->appendChild($mdDomDoc->createElement("LegendLabel"));
	$newNode->appendChild($mdDomDoc->createElement("ExpandInLegend",
"false"));
	$newNode->appendChild($mdDomDoc->createElement("Visible",
"true"));
	$newNode->appendChild($mdDomDoc->createElement("Group"));
	// Prepare the updated XML to be written out to the session.
	$updatedXml = $mdDomDoc->saveXML();
	$byteSource = new MgByteSource($updatedXml,
strlen($updatedXml));
	// Create a web layout in the session to hold the updated
version
	// from the library.
	$sessionMapName = $mdResourceId->GetName();
	$sessionMapDefinition =
"Session:$sessionId//$sessionMapName.MapDefinition";
	$sessionResourceId = new
MgResourceIdentifier($sessionMapDefinition);
	// Write the updated mapdefinition
	$resourceSrvc->SetResource($sessionResourceId,
$byteSource->GetReader(), null);
	//Test
	$md1 = "Session:$sessionId//X.MapDefinition";
	$mdResourceId2 = new MgResourceIdentifier($md1);
	$mdReader2 = $resourceSrvc->GetResourceContent($mdResourceId2);
	$mdXml2 = $mdReader2->ToString();
	$mdDomDoc2 = DOMDocument::loadXML($mdXml2);
	$wl = "Library://Test/Y.WebLayout"; // TODO Constant!
	$wlResourceId = new MgResourceIdentifier($wl);
	$wlReader = $resourceSrvc->GetResourceContent($wlResourceId);
	$wlXml = $wlReader->ToString();
	$wlDomDoc = DOMDocument::loadXML($wlXml);
	// Add the MapDefinition in the WebLayout
	$mapdef =
$wlDomDoc->getElementsByTagName("ResourceId")->item(0);
	$mapdef->nodeValue = "$md1";
	$wlupdatedXml = $wlDomDoc->saveXML();
	$wlbyteSource = new MgByteSource($wlupdatedXml,
strlen($wlupdatedXml));
version
	$wlsessionMapName = $wlResourceId->GetName();
	$wlsessionWebLayout =
"Session:$sessionId//$wlsessionMapName.WebLayout";
	$wlsessionResourceId = new
MgResourceIdentifier($wlsessionWebLayout);
	// Write the updated web layout to the session.
	$resourceSrvc->SetResource($wlsessionResourceId,
$wlbyteSource->GetReader(), null);
	// Redirect to the Ajax viewer pointing at the map at the
desired coordinates.
	$redirectTo =
"mapguide/mapviewerajax/?SESSION=$sessionId&WEBLAYOUT=$wlsessionWebLayou
t";
	$redirectTo =
"mapguide/mapviewerajax/?WEBLAYOUT=$wlsessionWebLayout&SESSION=$sessionI
d";
	$host = $_SERVER["HTTP_HOST"];
	$url = "http://$host/$redirectTo";
	function BuildLayerDefinitionContent()
	    global $dataSource, $featureName, $ffcolor, $fbcolor,
$transparent, $linestyle, $thickness, $lcolor, $fillstyle, $foretrans;
	    $xtrans = sprintf("%02x", 255 * $foretrans / 100);
	    $layerTempl =
file_get_contents("../../viewerfiles/arealayerdef.templ");
	    $xmlStr = sprintf($layerTempl,
	                      $dataSource,
	                      $featureName,
	                      "GEOM",
	                      $fillstyle,
	                      $xtrans . $ffcolor,
	                      $transparent? "ff" . $fbcolor: "00" .
$fbcolor,
	                      $linestyle,
	                      $thickness,
	                      $lcolor);
	    $src = new MgByteSource($xmlStr, strlen($xmlStr));
	    return $src->GetReader();
	function GetMapSrs($map)
	    $srs = $map->GetMapSRS();
	    if($srs != "")
	        return $srs;
	    //No SRS, set to ArbitrayXY meters
	   return "LOCALCS[\"Non-Earth (Meter)\",LOCAL_DATUM[\"Local
Datum\",0],UNIT[\"Meter\", 1],AXIS[\"X\",EAST],AXIS[\"Y\",NORTH]]";
	Regards,
	Arnaud De Groof
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
	Sent: vendredi 9 janvier 2009 9:03
MapGuide
	You need several steps.
	5. Refresh the map
	This is a generic recipe for building dynamic layers, redlining,
buffering, etc.
	There exist code that does this in the "buffer" function used in
the basic AJAX viewer.
	Look at the "buffer.[php,aspx,jsp]" file in:
	C:\Program
Files\MapGuideOpenSource2.0\WebServerExtensions\www\mapviewer[php,net,js
p]
	If you have trouble with one of the steps, please ask again.
	An easier way of dealing with it would be to create a layer that
displays ALL points.
	Then use the SQL WHERE statement as the layers "filter"
property.
	This approach obviously has some limitations.
	Regards, Kenneth Skovhede, GEOGRAF A/S
	Carmelo Saffioti skrev:
	Hi everybody!
	I hope you can help me about this problem I'm having since
several days:
	1) having x,y coordinates of a point, resulting from a sql
query, how can I display it at runtime on the map?
	2) having x,y coordinates of a sequence of points, resulting
from a sql query, how can I display them at runtime on the map?
	I really hope you can help me with that
	Thank you very much in advance
	Carmelo
	mapguide-users mailing list
	http://lists.osgeo.org/mailman/listinfo/mapguide-users
	E-MAIL DISCLAIMER
	The present message may contain confidential and/or legally
privileged information. If you are not the intended addressee and in
case of a transmission error, please notify the sender immediately and
destroy this E-mail. Disclosure, reproduction or distribution of this
document and its possible attachments is strictly forbidden.
	SPACEBEL denies all liability for incomplete, improper,
inaccurate, intercepted, (partly) destroyed, lost and/or belated
transmission of the current information given that unencrypted
electronic transmission cannot currently be guaranteed to be secure or
error free.
	Upon request or in conformity with formal, contractual
agreements, an originally signed hard copy will be sent to you to
confirm the information contained in this E-mail.
	SPACEBEL denies all liability where E-mail is used for private
use.
	SPACEBEL cannot be held responsible for possible viruses that
might corrupt this message and/or your computer system.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090112/6a919181/attachment.html
