[mapguide-users] Theme layer - error
Zac Spitzer zac.spitzer at gmail.com
Mon Jan 12 09:30:49 EST 2009
quick guess    <Color>FF808080</Color>
On Tue, Jan 13, 2009 at 1:16 AM, Arnaud De Groof
<Arnaud.DeGroof at spacebel.be> wrote:
> Here the LayerDefinition:
> <?xml version="1.0" encoding="utf-8"?>
> <LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd"
> version="1.1.0">
>  <VectorLayerDefinition>
>    <ResourceId>Library://Test/testpoly.FeatureSource</ResourceId>
>    <FeatureName>Default:New_Shapefile</FeatureName>
>    <FeatureNameType>FeatureClass</FeatureNameType>
>    <Filter />
>    <PropertyMapping>
>      <Name>T2</Name>
>      <Value>T2</Value>
>    </PropertyMapping>
>    <PropertyMapping>
>      <Name>T1</Name>
>      <Value>T1</Value>
>    </PropertyMapping>
>    <Geometry>Geometry</Geometry>
>    <Url />
>    <ToolTip />
>    <VectorScaleRange>
>      <AreaTypeStyle>
>        <AreaRule>
>          <LegendLabel />
>          <AreaSymbolization2D>
>            <Fill>
>              <FillPattern>Solid</FillPattern>
>              <ForegroundColor>ff808080</ForegroundColor>
>              <BackgroundColor>ff808080</BackgroundColor>
>            </Fill>
>            <Stroke>
>              <LineStyle>Solid</LineStyle>
>              <Thickness>0</Thickness>
>              <Color>808080</Color>
>              <Unit>Millimeters</Unit>
>              <SizeContext>MappingUnits</SizeContext>
>            </Stroke>
>          </AreaSymbolization2D>
>        </AreaRule>
>      </AreaTypeStyle>
>    </VectorScaleRange>
>  </VectorLayerDefinition>
> </LayerDefinition>
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: lundi 12 janvier 2009 15:11
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Theme layer - error
> can you post your layer xml?
> On Tue, Jan 13, 2009 at 1:02 AM, Arnaud De Groof
>> Hi,
>> I have a problem with the function "Theme layer". With the Sheboygan
> example
>> (district layer), the function is successful used but when I try to
> use this
>> function with my different polygon layers, the following error is
>> encountered during the process:
>> Error: An exception occurred in DB XML component.
>>         Error: XML Indexer:  Parse error in document at line, 72, char
> 12.
>> Parser message: Not enough elements to match content model :
>> '((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
>>  StackTrace:
>>   - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
> \resource\ResourceServiceHandler.cpp
>>   - MgOpSetResource.Execute line 103 file
> \resource\OpSetResource.cpp
>>   - MgServerResourceService.SetResource line 713 file
> \resource\ServerResourceService.cpp
>>   - MgRepositoryManager.SetResource line 867 file
> \resource\RepositoryManager.cpp
>>   - MgRepositoryManager.AddResource line 840 file
>>   - MgResourceContentManager.AddResource line 183 file
> \resource\ResourceContentManager.cpp
>>   - MgResourceContentManager.PutDocument line 624 file
>>   - MgResourceDefinitionManager.PutDocument line 554 file
> \resource\ResourceDefinitionManager.cpp
>> Error: XML Indexer:  Parse error in document at line, 72, char 12.
> Parser
>> Moreover, is it possible to configure this function aiming to apply a
>> graduated color depending to the attribute value?
>> Thanks.
>> Regards,
>> Arnaud De Groof
>> ________________________________
>> E-MAIL DISCLAIMER
>> The present message may contain confidential and/or legally privileged
>> information. If you are not the intended addressee and in case of a
>> transmission error, please notify the sender immediately and destroy
> this
>> E-mail. Disclosure, reproduction or distribution of this document and
> its
>> possible attachments is strictly forbidden.
>> SPACEBEL denies all liability for incomplete, improper, inaccurate,
>> intercepted, (partly) destroyed, lost and/or belated transmission of
> the
>> current information given that unencrypted electronic transmission
> cannot
>> currently be guaranteed to be secure or error free.
>> Upon request or in conformity with formal, contractual agreements, an
>> originally signed hard copy will be sent to you to confirm the
> information
>> contained in this E-mail.
>> SPACEBEL denies all liability where E-mail is used for private use.
>> SPACEBEL cannot be held responsible for possible viruses that might
> corrupt
>> this message and/or your computer system.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
Zac Spitzer -
+61 405 847 168
