[mapguide-users] Theme layer - error
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Mon Jan 12 17:16:23 EST 2009
The error message states:
Error: XML Indexer:  Parse error in document at line, 72, char 12.
message: Not enough elements to match content model :
'((LineStyle,Thickness,Color,Unit,SizeContext),ExtendedData1)'
The message is that the tag closing on line 72 should have the above
tags (LineStyle, ...., SizeContext),
but it does not.
However, the layer xml you sent, only contains 44 lines, so the layer
that fails to save is clearly another one.
Regards, Kenneth Skovhede, GEOGRAF A/S
Arnaud De Groof skrev:
> The same error is always present.
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Zac Spitzer
> Sent: lundi 12 janvier 2009 15:31
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] Theme layer - error
> quick guess    <Color>FF808080</Color>
> On Tue, Jan 13, 2009 at 1:16 AM, Arnaud De Groof
> <Arnaud.DeGroof at spacebel.be> wrote:
>> Here the LayerDefinition:
>> <?xml version="1.0" encoding="utf-8"?>
>> <LayerDefinition xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
>> xsi:noNamespaceSchemaLocation="LayerDefinition-1.1.0.xsd"
>> version="1.1.0">
>>  <VectorLayerDefinition>
>>    <ResourceId>Library://Test/testpoly.FeatureSource</ResourceId>
>>    <FeatureName>Default:New_Shapefile</FeatureName>
>>    <FeatureNameType>FeatureClass</FeatureNameType>
>>    <Filter />
>>    <PropertyMapping>
>>      <Name>T2</Name>
>>      <Value>T2</Value>
>>    </PropertyMapping>
>>    <PropertyMapping>
>>      <Name>T1</Name>
>>      <Value>T1</Value>
>>    </PropertyMapping>
>>    <Geometry>Geometry</Geometry>
>>    <Url />
>>    <ToolTip />
>>    <VectorScaleRange>
>>      <AreaTypeStyle>
>>        <AreaRule>
>>          <LegendLabel />
>>          <AreaSymbolization2D>
>>            <Fill>
>>              <FillPattern>Solid</FillPattern>
>>              <ForegroundColor>ff808080</ForegroundColor>
>>              <BackgroundColor>ff808080</BackgroundColor>
>>            </Fill>
>>            <Stroke>
>>              <LineStyle>Solid</LineStyle>
>>              <Thickness>0</Thickness>
>>              <Color>808080</Color>
>>              <Unit>Millimeters</Unit>
>>              <SizeContext>MappingUnits</SizeContext>
>>            </Stroke>
>>          </AreaSymbolization2D>
>>        </AreaRule>
>>      </AreaTypeStyle>
>>    </VectorScaleRange>
>>  </VectorLayerDefinition>
>> </LayerDefinition>
> Spitzer
>> Sent: lundi 12 janvier 2009 15:11
>> can you post your layer xml?
>> On Tue, Jan 13, 2009 at 1:02 AM, Arnaud De Groof
>>> Hi,
>>> I have a problem with the function "Theme layer". With the Sheboygan
>> example
>>> (district layer), the function is successful used but when I try to
>> use this
>>> function with my different polygon layers, the following error is
>>> encountered during the process:
>>> Error: An exception occurred in DB XML component.
> char
>> 12.
>>> Parser message: Not enough elements to match content model :
>>>  StackTrace:
>>>   - MgResourceServiceHandler.ProcessOperation line 80 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services
>> \resource\ResourceServiceHandler.cpp
>>>   - MgOpSetResource.Execute line 103 file
>> \resource\OpSetResource.cpp
>>>   - MgServerResourceService.SetResource line 713 file
>> \resource\ServerResourceService.cpp
>>>   - MgRepositoryManager.SetResource line 867 file
>> \resource\RepositoryManager.cpp
>>>   - MgRepositoryManager.AddResource line 840 file
>>>   - MgResourceContentManager.AddResource line 183 file
>> \resource\ResourceContentManager.cpp
>>>   - MgResourceContentManager.PutDocument line 624 file
>>>   - MgResourceDefinitionManager.PutDocument line 554 file
>> \resource\ResourceDefinitionManager.cpp
>> Parser
>>> Moreover, is it possible to configure this function aiming to apply a
>>> graduated color depending to the attribute value?
>>> Thanks.
>>> Regards,
>>> Arnaud De Groof
>>> ________________________________
>>> E-MAIL DISCLAIMER
>>> The present message may contain confidential and/or legally
> privileged
>>> information. If you are not the intended addressee and in case of a
>>> transmission error, please notify the sender immediately and destroy
>> this
>>> E-mail. Disclosure, reproduction or distribution of this document and
>> its
>>> possible attachments is strictly forbidden.
>>> SPACEBEL denies all liability for incomplete, improper, inaccurate,
>>> intercepted, (partly) destroyed, lost and/or belated transmission of
>> the
>>> current information given that unencrypted electronic transmission
>> cannot
>>> currently be guaranteed to be secure or error free.
>>> Upon request or in conformity with formal, contractual agreements, an
>>> originally signed hard copy will be sent to you to confirm the
>> information
>>> contained in this E-mail.
>>> SPACEBEL denies all liability where E-mail is used for private use.
>>> SPACEBEL cannot be held responsible for possible viruses that might
>> corrupt
>>> this message and/or your computer system.
>>> mapguide-users mailing list
>>> mapguide-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Zac Spitzer -
>> http://zacster.blogspot.com
>> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090112/59e28c5e/attachment.html
