[mapguide-users] FF 3 ...AJAX viewer does not load map
shad0wsong shad0wsong at yahoo.com
Tue Jan 13 18:21:07 EST 2009
I was having an annoying mouse zoom problems under FF3 using the AJAX viewer.
when i scroll to zoom, it's not zooming where my cursor is pointing, it's
always too far left or right.
I tracked it down to being in the function "HandleMouseWheelEvent". It's
using "event.screenX" for FF. The problem shows up with a dual screen setup.
Having the browser in the second screen inflates the screenX value and makes
the map zooms in wrong. The fix is change the "event.screenX" to
"event.pageX"
Hope this helps!
Le Ingenieur Inconnu wrote:
> BruceWeston wrote:
>> That helps load the map but everything else is a bit flaky - especially
>> ajax mouse zooms.
>> Tom Chadwin wrote:
>>> That works to a certain extent (FF3 on XPSP3, MGOS2 on W2K3 IIS PHP).
>>> The map (and legend) now loads, but my rasters do not always show up,
>>> and sometimes I cannot zoom.
> I have also had problems with selection. Having applied the same procedure
> of replacing POSTs by GETs  it seems that it is working better now. The
> changes have been applied to SetSelection(), ZoomSelection() and
> RequestHyperlinkData(). Attached is the changed ajaxmappane.templ.
>  http://n2.nabble.com/file/n1816790/ajaxmappane.templ ajaxmappane.templ
View this message in context: http://n2.nabble.com/FF-3-...AJAX-viewer-does-not-load-map-tp1816786p2153983.html
