[mapguide-users] Upload .shp file
Jackie Ng jumpinjackie at gmail.com
Thu Jan 22 02:00:57 EST 2009
Are you using MapGuide Studio or Maestro?
If you are using MapGuide Studio, create a Load Procedure containing the SHP
files you want to upload. The load procedure will create the Feature Sources
and Layers Definitions for you.
If you are using MapGuide Maestro, this link explains how to create Feature
Sources
(http://trac.osgeo.org/mapguide/wiki/maestro/UserGuides/FileFeatureSource)
- Jackie
Anushri wrote:
> Anushri wrote:
>> Can u plz explain following containt.
>> I am NOT getting it properly.
>> ajid wrote:
>>> My way im upload shp and dbf file.. if dont have OGR DataConnection.. U
>>> can upgrade FDO..
>>> Select FDO Provider for SHP and put shp and dbf file..
View this message in context: http://n2.nabble.com/Upload-.shp-file-tp2196349p2196489.html
