[mapguide-users] Fusion and phpviewersample application - error session ID
Arnaud De Groof Arnaud.DeGroof at spacebel.be
Thu Jan 29 04:05:07 EST 2009
I have changed the parameter 'SESSION' by 'session' but there is no
change. The following error is yet encountered:
Error
Invalid argument(s): [1] = "" The session ID is invalid because the
session separator character was not found.
session separator character was not found. Exception occurred in method
MgUserInformation.SetMgSessionId at line 183 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecomm
on\System/UserInformation.cpp
In fact, this error occurs when the application is invoked. The same
issue is encountered with others applications from the "phpviewersample"
(theme layer, query) which are use in a flexible layout.
Are there specific modifications to use the "phpviewersample"
applications with a flexible layout?
Thanks,
Arnaud De Groof
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Chris
Claydon
Sent: vendredi 23 janvier 2009 18:33
To: MapGuide Users Mail List
Subject: [mapguide-users] RE: Fusion php application - error session ID
See if you can capture the request that gets sent to thememain.php using
Fiddler. It is probably something simple, like Fusion sending the
session parameter using lowercase 'session' instead of 'SESSION'. If
that's the case, you should be able to update the php script to look for
the lowercase version if the uppercase one isn't defined.
Chris.
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Arnaud De
Groof
Sent: Friday, January 23, 2009 9:24 AM
Subject: [mapguide-users] Fusion php application - error session ID
I try to use the php application "theme layer" in a Fusion layout
without success. The following error is encountered during the process:
Error
Could you help me the resolve this issue because with a normal layout,
there is no error?
Thanks.
Regards,
Arnaud De Groof
___________________________________________________________________________________
E-MAIL DISCLAIMER
The present message may contain confidential and/or legally privileged information.
If you are not the intended addressee and in case of a transmission error,
please notify the sender immediately and destroy this E-mail.
Disclosure, reproduction or distribution of this document and its possible
attachments is strictly forbidden.
SPACEBEL denies all liability for incomplete, improper, inaccurate, intercepted,
(partly) destroyed, lost and/or belated transmission of the current information
given that unencrypted electronic transmission cannot currently be guaranteed
to be secure or error free. Upon request or in conformity with formal, contractual
agreements, an originally signed hard copy will be sent to you to confirm
the information contained in this E-mail.
SPACEBEL denies all liability where E-mail is used for private use.
SPACEBEL cannot be held responsible for possible viruses that might corrupt this
message and/or your computer system.
____________________________________________________________________________________
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090129/1e5bccc9/attachment.html
