[mapguide-users] Maintaining MapGuide Session during Restart
Bruce Dechant bruce.dechant at autodesk.com
Thu Jan 29 17:11:14 EST 2009
Bruce,
You can keep move some of the session data to the library - ie: resources that you have created in the session.
What you are asking is for the session state information to be maintained - that information cannot be replicated in the library.
I'm not a web developer, but what about using cookies with your custom web application to reestablish the MapGuide session how it was last left. Perhaps someone with experience with this could chime in.
Thanks,
Bruce
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of bruce_weston
Sent: Thursday, January 29, 2009 8:54 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Maintaining MapGuide Session during Restart
Bruce D,
Are you suggesting that this can be done? Does anyone have a script or a
method of copying the session repository into a library object? Is there
even a way of creating a copy of the session as XML?
thanks,
Bruce W
Bruce Dechant wrote:
> Bruce,
> What you are doing by trying to replace the session repository of a
> running server is problematic and could lead to server instability. You
> really shouldn't do this.
> The session repository is meant for temporary runtime data only and not
> for persistent data. If you want any of your session repository data to
> survive a restart you need to use the library repository instead.
> Thanks,
> Bruce
> Sent: Wednesday, January 28, 2009 2:34 AM
> Subject: [mapguide-users] Maintaining MapGuide Session during Restart
> I'm just wondering if anyone has managed to do this yet? This is my
> attempted
> MapGuide restart script to keep the contents of the session folder backed
> up, but it doesn't work:
> echo MapGuide Scheduler Task Starting
> taskkill /F /FI "SERVICES eq MapGuideServer2.0"
> net stop MapGuideServer2.0
> REM xcopy c:\Progra~1\MapGuideOpenSource2.0\Server\Repositories\Session\*
> c:\Progra~1\MapGuideOpenSource2.0\SessionBackup\ /E /Y
> net start MapGuideServer2.0
> REM xcopy c:\Progra~1\MapGuideOpenSource2.0\SessionBackup\*
> c:\Progra~1\MapGuideOpenSource2.0\Server\Repositories\Session\ /E /Y
> echo MapGuide Scheduler Task Completed
> pause
> Is there session data stored anywhere else? I really want to make the
> process seamless for my users.
> Bruce
> http://n2.nabble.com/Maintaining-MapGuide-Session-during-Restart-tp2231199p2231199.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://n2.nabble.com/Maintaining-MapGuide-Session-during-Restart-tp2231199p2239668.html
