[mapguide-users] Mapguide raster problem
Klemen S. klemen.sorcnik at gmail.com
Sat Jan 31 04:21:32 EST 2009
I dont recommend  to use autodesk raster provider  becouse is extremly  slow.
My measurment  between MGOS raster provider and autodesk raster provider
show me that autodesk raster provider is at last  2x or more slower. What is
not acceptable.
Klemen
zspitzer wrote:
> or buy a license for MGE and use the autodesk raster provider ...
> I managed to demonstrate the problem to the autodesk team with a good test
> case
> and they are going to look into the problem...
> z
> On Tue, Jan 20, 2009 at 6:35 PM, Maciej Skorczewski
> <maciej.skorczewski at procad.pl> wrote:
>> Hi!
>> My advice is:
>> 1. Add Raster layer whit scale (ex. when user goto or zoom to scale 2000
>> the
>> you display layer, you can set this in: Scale range - MG Studio,raster
>> layer
>> style).
>> 2. add scrit to your serwer who will reset mgserwice cyclically, this can
>> help when mgserwer display raster (mgserwice have big problem with
>> stability), mgservice can get to 300MB of ram, and that slow down all, or
>> it
>> stop working.
>> 3. You can try to add Base Layers, but in may opinion this is no good
>> solution,because when Mgserver thry to generate image tile image
>> mgservice
>> can hand down... (try to set this and take a look on CPU and RAM)
>> 4. Try to reduce your raster files.
>> In may project was about 10GB of Raster files, i cut size to 3GB, after
>> add
>> Scale range all works fine , my rating is 8/10
>> macieksk
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
View this message in context: http://n2.nabble.com/Mapguide-raster-problem-tp2180266p2249360.html
