[mapguide-users] MapGuide (OpenSource/Enterprise) crashes when using Oracle provider (King.Oracle)
Joel Carranza jec at gatekeeper.com
Thu Jul 2 12:53:58 EDT 2009
I have a similar problem. MapGuide crashes sporadically on an layer being
rendered by King.Oracle. I was unable to repeat the problem. That is - I
restarted mapguide, deleted the tile that failed to render, and made the
request a second time. It succeeded without a problem. Thus I can only
assume it is not a problem with the source geometry or layer config, but
some problem with concurrent map requests, as that is when it seems most of
my problems occur.
For example, I haven't have problems when I generate tiles via the MgCooker,
but only when I am lazily rendering tiles as I am randomly view a map. Does
MgCooker request tiles single-threadedly?
Joel Carranza
Gatekeeper Systems
<2009-07-02T09:40:01>   5616    JV-1097,674,0   207.168.238.188
Administrator
 Error: Failed to stylize layer: TIGERStreetByType
        An unclassified exception occurred.
 StackTrace:
  - MgMappingUtil.StylizeLayers() line 776 file
c:\osgeo\mapguide_21\mgdev\serve
r\src\services\mapping\MappingUtil.cpp
sathishpsk9 wrote:
> Hi elkinsalcedo
>  I too same error log ......... have resolve it The problem is with
> mapguide or with oracle ?
> Thanks & Regards,
> satish
View this message in context: http://n2.nabble.com/MapGuide-%28OpenSource-Enterprise%29-crashes-when-using-Oracle-provider-%28King.Oracle%29-tp1819405p3196272.html
