[mapguide-users] Can you connect to mapguide across a network?
JamesDudden jamesdudden at blueyonder.co.uk
Mon Jul 6 05:35:30 EDT 2009
I have set up and been using Mapguide for a few months now using: MG2,
Studio09, Xp, ASP.NET, IIS 5
The computer is on a small local network. Is it possible to view my Mapguide
application and map admin from a different computer on the network?
I have tried using the computers name and ip address as follows:
http://192.168.1.3/mapguide/mapadmin/login.php
http://dell3100/mapguide/mapadmin/login.php
Both of these give the same error:
Internet Explorer cannot display the webpage
Most likely causes:
You are not connected to the Internet.
The website is encountering problems.
There might be a typing error in the address.
Is there something I need to do in IIS?
Or is this just not possible?
Any help, advice or comments are welcomed.
Regards
JD
http://www.software-matters.co.uk Software Matters  -
http://www.software-matters.co.uk/bespoke-database-design.html Bespoke
Database  and Software Solutions
View this message in context: http://n2.nabble.com/Can-you-connect-to-mapguide-across-a-network--tp3212174p3212174.html
