[mapguide-users] SQL Server Data not appearing in Fusion
kevin_t tai_kevin at hotmail.com
Tue Jul 7 15:26:42 EDT 2009
>From the Apache error log:
"PHP Fatal error:  Allowed memory size of 67108864 bytes exhausted (tried to
allocate 34674 bytes) in C:\\Program
Files\\Autodesk\\MapGuideEnterprise2010\\WebServerExtensions\\www\\fusion\\common\\php\\Utilities.php
on line 42, referer: <long URL to my fusion layout>"
I opened the utilities.php and looked at line 42.  Nothing seems out of the
ordinary.  I wonder where this "allowed memory size" setting is.
I found a posting that describes someone having to increase PHP memory to
get their fusion to work.  Is this related?
http://n2.nabble.com/Unmanaged-Performance-td1818163.html#a1818163
Paul Spencer wrote:
> can you check your apache error log.  I expect it is a bug in Fusion's
> php code.
> Cheers
> Paul
> On 7-Jul-09, at 1:51 PM, kevin_t wrote:
>> Hi all,
>> I have a problem where my map in a fusion/flexible layout doesn't
>> load in my
>> browser if I have data from SQL Server 2008.  It loads fine in the
>> basic
>> layout, so it is unlikely that it's a SQL Server issue.  I am using
>> MapGuide
>> Enterprise 2010 with SQL Server 2008 Trial version.  The browser I
>> tested
>> are Firefox and IE.
>> My steps are as follows:
>> - Import shapefile to SQL Server 2008 using SQL Server 2008 Spatial
>> Tools.
>> - Create a data connection in MG Studio 2010 to it with the OSGeo FDO
>> Provider for SQL Server Spatial.
>> - Create the layer and add it to a map that is referenced by a fusion
>> layout.
>> - View the layout in a browser.
>> Does anyone know if this is a bug with fusion layouts and if there
>> is a
>> workaround?
>> View this message in context:
>> http://n2.nabble.com/SQL-Server-Data-not-appearing-in-Fusion-tp3220760p3220760.html
>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/SQL-Server-Data-not-appearing-in-Fusion-tp3220760p3221403.html
