[mapguide-users] Feature Vertices
Jackie Ng jumpinjackie at gmail.com
Tue Jul 7 17:36:23 EDT 2009
If GetGeometryType() return MgGeometryType.Polygon, then yes you can safely
cast it to a MgPolygon.
- Jackie
Tom Lazo wrote:
> Hi Jackie,
> Just one question, is the geometry cast just and (MgPolygon) geometry?,
> srry about my ignorance. n.n' . I think i should use the geometry's
> Boundary function. But i dunno how, i've looked everywhere without luck.
> Plz help.
> Thanks
> Tom / Stygy
> Jackie Ng wrote:
>> Given a MgFeatureReader that contains your feature(s):
>> - Call its GetGeometry() method to get a byte reader
>> - Convert this byte reader to a MgGeometry object by using a
>> MgAgfReaderWriter object.
>> - Call GetGeometryType() on the MgGeometry to determine what type of
>> geometry it actually is.
>> - Depending on the type, cast the MgGeometry to that given type (if not
>> using PHP) and consult the relevant APIs for that derived geometry type.
>> Basically you want to take note of any class methods that return MgPoint,
>> MgCoordinate or MgCoordinateIterator objects.
>> Hope that helps.
>> - Jackie
>> Tom Lazo wrote:
>>> Hi all!,
>>> Anyone knows how could i get the coordinates of the vertices of a
>>> feature, Is there any function that do that?. Thanks.
>>> Stygy / Tom
View this message in context: http://n2.nabble.com/Feature-Vertices-tp3205810p3221973.html
