[mapguide-users] Geometric join without spatial support
Tom Lazo tom.lazo at hotmail.com
Wed Jul 8 12:20:46 EDT 2009
I'm in the same situation. But, i think that can be solved with the
MgGeometry class. I dunno but you could  do a "double for" and apply the
"Within" Function for each feature.
Take a time and read this class:
http://mapguide.osgeo.org/files/mapguide/docs/2.0/d1/d85/class_mg_geometry.htm
I dunno how slow could be the process. But that could be a solution.
Well, let me know if it works.
Tom / Stygy
dorshemer wrote:
> Hello,
> I'm trying to perform a geometric join between two tables without using
> any spatial DB support.
> I have an oracle table representing points on a map with X and Y fields,
> and a polygon SHP layer imported into MG. I would like to connect all the
> point from the first table with the polygons they are contained in,
> without Oracle Spatial support or writing new code.
> Is it even possible?
View this message in context: http://n2.nabble.com/Geometric-join-without-spatial-support-tp3208010p3226444.html
