[mapguide-users] Create Points Layer From Coordinates
Dave Wilson dave.wilson at autodesk.com
Fri Jul 10 15:12:26 EDT 2009
One option would be to use an Access or other database via ODBC. The table structure is very simple. You just need an X and Y column for your vertex values. You can add your letter as a label column and label them as part of the point layer or if the labels need to be fixed create a second layer with the coordinate values for the letters and create a text layer also using an ODBC connection.
Dave
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Tom Lazo / Stygy
Sent: Friday, July 10, 2009 11:57 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Create Points Layer From Coordinates
Hi all,
Srry, I searched for information, but can not find a way to create a layer
of points from  their coordinates.
I mean, I have a feature and what I do is take their vertices, once I got
the vertices' coordinates i want to draw letters on them to identify
them...something like this
http://www.sbn.gob.pe/sbn1/wtemporales/avisos/DS-195-2006-enero2007/docs-modelos/Plano-01.jpg
Example
Thanks.
Tom
http://n2.nabble.com/file/u222842/warning.png   Stygy is not a living being!
View this message in context: http://n2.nabble.com/Create-Points-Layer-From-Coordinates-tp3237097p3237097.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
