[mapguide-users] Geometric join without spatial support
dorshemer dorshemer at gmail.com
Sun Jul 12 08:06:33 EDT 2009
Thanks for the advice.
I ended up using a spatial filter with
http://mapguide.osgeo.org/files/mapguide/docs/2.0/d8/dcc/class_mg_feature_query_options_3e8bc4869a6eae290c4d06ebd91823ca.htm#3e8bc4869a6eae290c4d06ebd91823ca
MgFeatureQueryOptions::SetSpatialFilter()  to create a new FeatureSource as
Jamo suggested, then created a new layer based on it.
Tom Lazo / Stygy wrote:
> Hi,
> I'm in the same situation. But, i think that can be solved with the
> MgGeometry class. I dunno but you could  do a "double for" and apply the
> "Within" Function for each feature.
> Take a time and read this class:
> http://mapguide.osgeo.org/files/mapguide/docs/2.0/d1/d85/class_mg_geometry.htm
> I dunno how slow could be the process. But that could be a solution.
> Well, let me know if it works.
> Tom / Stygy
> dorshemer wrote:
>> Hello,
>> I'm trying to perform a geometric join between two tables without using
>> any spatial DB support.
>> I have an oracle table representing points on a map with X and Y fields,
>> and a polygon SHP layer imported into MG. I would like to connect all the
>> point from the first table with the polygons they are contained in,
>> without Oracle Spatial support or writing new code.
>> Is it even possible?
View this message in context: http://n2.nabble.com/Geometric-join-without-spatial-support-tp3208010p3245587.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090712/9b4b8c6e/attachment.html
