[mapguide-users] After Installation, Services Missing
Zac Spitzer zac.spitzer at gmail.com
Mon Jul 13 11:40:13 EDT 2009
so, anyway, what are you trying to do (config) with these services?
you can always manually configure the services via the serverconfig.ini file
in server\bin if thats what your trying to do.
Can you view maps?
if so then generally speaking those services are installed and working?
z
On Tue, Jul 14, 2009 at 1:13 AM, Dennis Soper<dsoper at uoregon.edu> wrote:
> No, I'm talking about when you log in to the web interface.  Under
> "Manage Servers->Configure Services".  The only services listed are:
> Site Services, Resource Services, Feature Service, and Tile Service.
> According to the help files there should also be Drawing, Mapping, and
> Rendering.  There was another page in the help files that might have
> told me how to fix this, but, unfortunately, I got a 404 error when I
> tried to access it.
> Cheers,
> Dennis
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Stefan
> Dalakov
> Sent: Saturday, July 11, 2009 8:08 AM
> To: MapGuide Users Mail List
> Subject: Re: [mapguide-users] After Installation, Services Missing
> Hi Dennis,
> I do not understand very well what is the problem. From where are they
> missing ? Do you expect to see them as services running under windows ?
> Or you have used web tier tests and you do not get the expected results
> Under Windows services you should see only one service - MapGuide Server
> v.xxx
> I have not dared to install mgos 2.1 yet, but I don't expect that it
> will differ very much from previous versions in respect of what you are
> asking about
> Stefan Dalakov
> Dennis Soper wrote:
>> Hi all,
>> I've installed MapGuide Open Source on a test machine. The following
>> services are missing from the web-based configuration: Drawing,
>> Mapping, and Rendering. I've loaded it on a Windows 2003 box, using
>> IIS, and I've tried both the .NET and PHP environments.
>> How do I get these services?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
