[mapguide-users] generating thematic layer programmatically
Tom Lazo / Stygy tom.lazo at hotmail.com
Mon Jul 13 16:16:29 EDT 2009
I dunno if this could help...but i had the same problem, but i found a
solution on the Theme Layer of the phpviewersample:
http://mapguide.osgeo.org/download/releases/2.0.x-samples
But it actually doesn't work with fusion...as the beatles said...i found the
solution with a little help from my [Mapguide] friends xD. I post the
solution on this link so...look around and take your time xD
http://n2.nabble.com/Problems-With-the-phpviewersample's-Theme-Layer-on-Fusion---Here's-my-solution-td3164056.html#a3164056
Hope it helps.
Tom
girish kumar bv wrote:
> Hi all,how to create thematic layer programmatically in mapguide. My
> requirement is to generate an thematic layer for a given layer in map and
> convert the thematic layer in to kml file. Any help is
> appreciated.regards,girish
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
http://n2.nabble.com/file/u222842/warning.png   Stygy is not a living being!
View this message in context: http://n2.nabble.com/re%3A-generating-thematic-layer-programmatically-tp3250778p3252744.html
