[mapguide-users] Mapguide is displaying wrong coordinates
psergio psergio at mediaprimer.pt
Tue Jul 14 09:42:31 EDT 2009
Hi Stefan,
Thanks for your reply.
I'm using AJAX and turning on Properties pane don't fix my problem.
I think that it can be a problem in OGR or PostGis providers, because if i
use SDF Files the geometry is displayed in the wright place in MapGuide.
Have you noticed any similar problem?
Many thanks
Paulo Azevedo
S.Dalakov wrote:
> Hi Paulo,
> are you using Ajax or Fusion ?
> Sometime ago there was a bug concerning shift of coordinates in Ajax
> when Properties pane in Ajax is not switched ON. Chris Claydon provided
> patch for this, you can search the forum. I don't know if this is the
> case. Do you have other layers? Is this point shifted compared to them?
> Stefan Dalakov
> Paulo Azevedo wrote:
>> Hi all.
>> I’m having problems with MapGuide Open source displaying data from
>> PostGis Database using OGR Provider or PostGis Provider.
>> In my database I use EPSG: 27492, and MapGuide is configured with
>> coordinate system Datum73.ModPortgGrd (Datum73.ModPortgGrd), but the
>> points are not displayed correctly.
>> Example: in my database I have a point with coordinates
>> *-63949,495217; 15467,134032; 0* but on MapGuide it’s displayed in
>> *-64008,282557; 15291.623095; 0*
>> Any clue about what it’s happening in MapGuide?
>> Best regards,
>> Paulo Azevedo
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://n2.nabble.com/Mapguide-is-displaying-wrong-coordinates-tp3256362p3256863.html
