[mapguide-users] Transparency on IE6 for Selection
Jackie Ng jumpinjackie at gmail.com
Tue Jul 14 18:37:35 EDT 2009
Hi Dave,
I think it's this one:
http://trac.osgeo.org/fusion/changeset/1810
- Jackie
Dave Wilson wrote:
> It appears with the introduction of the RENDERDYNAMICOVERLAY for selection
> we aren't calling the alpha transparency check on the image being
> generated.
> I can't find in the code how this is done to suggest a fix.
> As a result selection on a fusion layout in IE6 doesn't have a transparent
> background.
> Can someone point me in the direction of where the fix is needed?
> Thanks,
> Dave
> [cid:image001.jpg at 01CA047B.E4436130]
> Dave Wilson, AEC IM
> CRT QA Analyst
> Autodesk Canada, Inc.
> 21st Floor
> 645 7th Ave SW
> Calgary, AB T2P 4G8
> Direct      403-538-3069
> Fax          403-264-1442
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Transparency-on-IE6-for-Selection-tp3258474p3259771.html
