[mapguide-users] set "filter applied to data" programmatically
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Jul 15 09:37:17 EDT 2009
Look at the buffer.* files in your MapGuide installation:
C:\Program
Files\MapGuideOpenSource\WebExtensions\www\mapviewer(php|net|java)\buffer.(aspx|jsp|php).
If you are using .Net, you can also try the MaestroAPI:
http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/ModifyLayerFilter
The approach used in the MaestroAPI example is the same you would use
in the other languages.
Regards, Kenneth Skovhede, GEOGRAF A/S
vittorio skrev:
> Thanks Kenneth for your reponse.
> I need to see code examples to load a new layer programmatically from a xml
> modified file.
> Can you post me kindly?
> Vittorio.
> Kenneth Skovhede, GEOGRAF A/S wrote:
>> The runtime map is a copy of the MapDefinition and references
>> LayerDefinitions.
>> You usually get to the Runtime map by calling MgMap.Open(...).
>> To modify the filter, you must modify the LayerDefinition that is
>> referenced by the
>> runtime map.
>> You need to get the LayerDefinition xml, and modify it.
>> If you save it, the layer will be modified for all users.
>> Instead, save a modified copy in the session repository.
>> The update the runtime map layer to point to the temporary
>> LayerDefinition.
>> Finally call Refresh in the client.
>> vittorio skrev:
>>> Hi all,
>>> how to set "filter applied to data" to a layer programmatically and make
>>> visible the result into map viewer?
>>> Thanks,
>>> Vittorio
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090715/ffa136ef/attachment.html
