[mapguide-users] Add layers to the map
euskalmap ziburudebian at free.fr
Wed Jul 15 10:25:33 EDT 2009
thanks, it's running.
so, the last question : i have adding 3 lines in my code to update the
filter of the layer (see  http://patxi.mayol.free.fr/public/test2.pdf my
sample , line 47).
This new modify do not run : How can i associate the new filter with the
layer ?
euskalmap.
Kenneth Skovhede, GEOGRAF A/S wrote:
> You should also set
> "layer.Visible = true;"
> when adding the layers.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> euskalmap skrev:
>> Hi,
>> In Masetro, I have 1 layout with a reference to a map (Library://Ag
>> Base/Carte/MyMap.MapDefinition); the map MyMap contents no layers because
>> i
>> want to load the layers dynamicly.
>> Another map MyMap_NEW contents 5 layers.
>> So, my code modify the resource in layout (mapdefinition become
>> Library://Ag
>> Base/Carte/MyMap_NEW.MapDefinition) and add the layers from MyMap_NEW.
>> Here is my  http://patxi.mayol.free.fr/public/test2.aspx code
>> when i load my web page, i see temporarily the layers on the left and 2
>> seconds later, they disappear : and no map is displaying!!
>> Have you an idea ?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://n2.nabble.com/Add-layers-to-the-map-tp3230740p3263518.html
