[mapguide-users] set "filter applied to data" programmatically
vittorio vittorio.ricchiuto at hsh.it
Thu Jul 16 04:29:06 EDT 2009
Hi Kenneth,
I gave a look at buffer.jsp file, but I have not found anything about xml. I
would like to understand how to add programmatically a layer from an xml
file.
Vittorio.
Kenneth Skovhede, GEOGRAF A/S wrote:
> Look at the buffer.* files in your MapGuide installation:
> C:\Program
> Files\MapGuideOpenSource\WebExtensions\www\mapviewer(php|net|java)\buffer.(aspx|jsp|php).
> If you are using .Net, you can also try the MaestroAPI:
> http://trac.osgeo.org/mapguide/wiki/maestro/MaestroAPI/samples/ModifyLayerFilter
> The approach used in the MaestroAPI example is the same you would use
> in the other languages.
> Regards, Kenneth Skovhede, GEOGRAF A/S
> vittorio skrev:
>> Thanks Kenneth for your reponse.
>> I need to see code examples to load a new layer programmatically from a
>> xml
>> modified file.
>> Can you post me kindly?
>> Vittorio.
View this message in context: http://n2.nabble.com/set-%22filter-applied-to-data%22-programmatically-tp3257298p3267725.html
