[mapguide-users] Mapguide Library Folders
Luis Paolini l_paolini at uol.com.br
Fri Jul 17 09:51:11 EDT 2009
Kenneth,
                Thanks for the information.
                Using GETRESOURCEDATA I can get the dwf files and do what I
need.
Best,
Luis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
Skovhede, GEOGRAF A/S
Sent: Friday, July 17, 2009 9:32 AM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Mapguide Library Folders
The name of the folder is random, and generated by MapGuide.
AFAIK, there is no way to retrieve the path.
Instead, you can call GetResourceData and retrieve the file:
http://localhost/mapguide/mapagent/index.html
Click "GetResourceData" to the lower left, fill out the ResourceId and
DataName and click Submit.
You can mimic the POST generated by the html form to do the same from a
program.
That is what the MaestroAPI does, when using the http connection, so you can
also use that to retrieve the file.
Regards, Kenneth Skovhede, GEOGRAF A/S
Luis Paolini skrev:
Dave,
                I need the dwf files because the client wants to load them
into oracle database in order to allow users to download them via an
application.
                I understand that they are published to a folder in the
Mapguide Site Explorer, but this folder name is logical and is not created
in the Mapguide Server.
                My problem is that I need to publish 600 DWG files and when
I do that, all the DWF files are created with the same name (Map Base.dwf).
                As we have many people working in this process, the
alternative to find the files manually sorting by date will not work.
                If I could define the name of the dwf file during
publishing, instead of the default Map Base.dwf, will solve the problem.
                The other option was to figure out the relation between the
logical name created in Site explorer and the physical name created in the
\Library\Datafiles.
Luis
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dave Wilson
Sent: Thursday, July 16, 2009 5:34 PM
Subject: RE: [mapguide-users] Mapguide Library Folders
What do you want to do with the files?
During the publish you specified a folder to publish to in the MapGuide Site
Explorer. All the files are created in a Data subdirectory under the folder
name you specified.
You can use MGE API's to EnumerateResource, EnumerateResourceData and
GetResourceData and get the files from the Repository.
Otherwise if you were simply looking to find the files manually after a
single publish you can view the Repositories\Library\DataFiles\ in Windows
Explorer and sort by date and see the files that were created. You could
search on .dwf and find the files.
Dave
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Luis Paolini
Sent: Thursday, July 16, 2009 1:48 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mapguide Library Folders
Hi All,
                I'm working with Autodesk Map 3D to publish some DWG files
to Mapguide in DWF format.  The process is:
File -> More Plotting Options -> Publish to Mapguide
Connect to Mapguide
Create a Folder
Publish
After that, looking into Mapguide Server Folders, I understand that my DWF
file was stored somewhere inside /Library folder.
The problem is that the folders are named by Mapguide using some pattern
(Ex: dfaaf08a-ffff-ffff-8000-00c09f3e1b02).
My question is: How can I discover in which folder the dwf published is
stored?
Regards,
Luis
__________ Information from ESET Smart Security, version of virus signature
database 4251 (20090716) __________
The message was checked by ESET Smart Security.
http://www.eset.com
http://www.eset.com
database 4253 (20090717) __________
http://www.eset.com
  _____
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
http://www.eset.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090717/2aac2d58/attachment.html
