[mapguide-users] MGOS Postgis FDO Stack
Haris Kurtagic haris at sl-king.com
Sun Jul 19 17:04:34 EDT 2009
not sure but it looks like 64bit / 32bit mix ?
Haris
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andre
Schoonbee
Sent: Sunday, July 19, 2009 10:35 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] MGOS Postgis FDO Stack
This was running on PostgisProvider.dll
Schoonbee
Sent: 19 July 2009 09:32 PM
Hi Haris
When running depandancy walker, I get thefollowing error:
Error: At least one module has an unresolved import due to a missing
export
function in an implicitly dependent module.
Error: Modules with different CPU types were found.
Warning: At least one module has an unresolved import due to a missing
export function in a delay-load dependent module.
The file that is giving the error is LIBEAY32.DLL which seems to be for
x64
CPU.
Other files flagged red are:
KERNEL32.DLL, SHLWAPI.DLL and IEFRAME.DLL
Andre
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Haris
Kurtagic
Sent: 19 July 2009 08:43 PM
To: MapGuide Users Mail List
have you checked with dependency walker ?
Haris
Schoonbee
Sent: Sunday, July 19, 2009 8:37 PM
Subject: [mapguide-users] MGOS Postgis FDO Stack
Importance: High
I have replaced my older notebook with a new one running Vista. I now
have
various problems in getting MGOS versions (2.0.1,2.0.2) with
Postgresql/Postgis 8.2 or 8.3. I have tried FDO postgis versions
3.1,3.2,3.3,3.4 and all of then gave me same errors:
The remote server returned an error: (559) MgFdoException.:
An exception occurred in FDO component.
Unable to load the FDO Provider: (null)
Exception occurred in method MgFdoConnectionManager.Open at line 262 in
file
d:\buildforgeprojects\mapguide_open_source_v2.0\build_27.16\mgdev\server
\src
\common\manager\FdoConnectionManager.cpp
I am now busy downloading MGOS 2.1 beta to see if it will work, but is
it
lately a problem to get MGOS to talk to postgis?
If not, what should the typical version stack be that could work 100%,
because I just about had it.
All installations was made with default settings and default locations.
I
also made sure that postgresql / bin directory is within my system path
and
that libpg.dll is located in the bin and lib directory for postgresql. I
can
connect to postgis and display the point info just fine using qgis.
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
