[mapguide-users] MG Error Out of memory, bad allocation
juergen.konradt at bluewin.ch juergen.konradt at bluewin.ch
Tue Jul 21 06:57:01 EDT 2009
I have a problem with a rasterlayer (not tiled).
It is a layer using about 1000 TIFF-Files (RGB, 3000x3000 pixel, scale 1:1000).
The visibility of the layer is 1:100 to 1:5000.
If I load the map (sacle 1:2000) I get the error: Out of memory. bad allocation.
If I reduce the number of tiff-files in the folder (500) I get no error but the map is loading very, very slow.
If I change the format from tiff to jpg or ecw (all 1000 files) I get no error but the map is also very slow.
I get the same error with Autodesk Raster FDO and OSGEO Gdal
MGOS 2.02 or MGOS 2.1.0 Beta
W2003 Server SP2
IIS 6.0
AjaxViewer (JSP)
is there any solution for this problem?
Jürgen
