[mapguide-users] Non-Administrator Users Can't Login
Mauricio Villablanca mgvillablanca at yahoo.com
Thu Jul 23 04:07:42 EDT 2009
You need to set the right permissions of the repository folders.
Bloozitis wrote:
> Hi,
> I've created a test user, assigned it to a "mapauthors" group I created,
> which assigns the user to the "Authors" role.  When I attempt to login as
> this user, I get an "Authentication failed.  Please enter a valid username
> and password.  The following message is in the error log:
> <2009-07-13T14:58:06> 	Map Admin	128.223.67.19	tester
>  Error: Unauthorized access.
>  StackTrace:
>   - MgSiteServiceHandler.ProcessOperation line 83 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\site\SiteServiceHandler.cpp
>   - MgOpEnumerateServers.Execute line 96 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\services\site\OpEnumerateServers.cpp
>   - MgSecurityManager.Authenticate line 213 file
> d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\server\src\common\manager\SecurityManager.cpp
> Any ideas what I'm doing wrong?  I'm running the bundled Apache on Windows
> 2003 Server with a PHP development environment.
> Cheers,
> Dennis
View this message in context: http://n2.nabble.com/Non-Administrator-Users-Can%27t-Login-tp3257838p3308151.html
