[mapguide-users] Weird Issue with Buffer and SDF's
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jul 24 02:59:34 EDT 2009
I'm guessing that this is a projection issue.
The buffer code is a bit sensitive when mixing coordinate systems,
which happens if one FeatureSource reports XY-M while
the map is using the correct projection.
Regards, Kenneth Skovhede, GEOGRAF A/S
Tom Lazo / Stygy skrev:
> Hi all,
> I've realized about a weird issue on mapguide...
> Well i have two layers Lotes and Manzanas. Lotes' data resource have been
> made with Maestro's Data Conection Tool (Shape) and Manzanas' data resource,
> with Autodesk Mapguide Studio.
> Ok as you now the Autodesk Mapguide Studio creates a Lotes.sdf and Maestro
> creates a "folder" that contains Manzanas.dbf, .idx, .sbn, .sbx, .shp and
> .shx. Ok, i've not had problems with these little differences...since today
> when i tried to create a buffer while selectin' Manzanas layer.
> Well, when i tried that..the buffer layer didn't show on the map...but it
> was on the leyend... then i tried with the Lotes layer.. and this really
> worked...
> Ok i know that the trouble are the date resource types..so please explain me
> about this problem.
> Thanks.
> Tom
> P.s. Again ..srry about my bad english.
> http://n2.nabble.com/file/u222842/warning.png   Stygy is not a living being!
