[mapguide-users] Select features on map load
Paulo Veríssimo pauloverissimo at hotmail.com
Fri Jul 24 10:40:10 EDT 2009
Hi Thierry,
I am glad we found a solution for this.
I know this isn't the best solution because it has to load the map with initial zoom and then selects the features and zooms for selection, so it takes a while, but it works.
Andy found a faster and more efficient solution.
http://www.mail-archive.com/mapguide-users@lists.osgeo.org/msg11544.html
He zooms to the feature at map first load.
You can see it working here:
http://smamap.com/mapguide/GreenMapSanMiguel/index.php?LAYER=food&LOCATION=BOVE&END
Maybe some another day I'll try to do that
Thank you for your message.
Paulo
Sent: Friday, July 24, 2009 3:24 PM
To: Paulo Veríssimo
Subject: Re: [mapguide-users] Select features on map load
Hi all,
Work's for me too.
Just a little bug with IE 6 : the empty frame (i.e. the frame with only php code and javascript to launch it) is not loaded if set to use the remaining space in the frameset (like rows="50,200,*) .
No problem with firefox.
Solved by setting row high to 1 pixel for this frame.
Thanks a lot
View message @ http://n2.nabble.com/Select-features-on-map-load-tp3174763p3315925.html
To unsubscribe from Re: Select features on map load, click here.
View this message in context: http://n2.nabble.com/Select-features-on-map-load-tp3174763p3316007.html
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090724/694dc05b/attachment.html
