[mapguide-users] Maptip's wrong position
Rodolfo Moreno rodolfoamoreno at gmail.com
Fri Jul 24 18:41:38 EDT 2009
Finally, I have already found out why the maptip is showing up in wrong
position. After of a long time I tried to solve it again. The problem is
that the SQLView must have spatial indexs as well. But it's not possible
because SQL asks for primary key in order to create the spatial indexs.
Therefore SQLViews with inner join always will have this problem.
Regards,
Rodolfo Moreno wrote:
> Hi All,
> maptip is showing up in the wrong position for SQL2008 layers which are
> SQLViews with inner join.
>  http://n2.nabble.com/file/n3143092/maptipIssue1.jpg
> The red circle(upper left corner of the maptip rectangle) in the image
> indicates the mouse pointer.
> however with SQLviews without inner join maptip is working correctly.
> I have tested with MG 2.0.2 + AJAX viewer and FUSION 1.1 and also with  MG
> 2.1 + AJAX viewer and FUSION 2. In all cases I can see the same issue.
> Any idea about it?
> Regards,
Rodolfo Moreno
CivilEng
View this message in context: http://n2.nabble.com/Maptip%27s-wrong-position-tp3143092p3323061.html
