[mapguide-users] mapguide examples won't display, can't create new resources, possible permissions setup problem?
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Wed Jul 29 03:23:36 EDT 2009
I think that is an issue with Maestro.
It should definately not create temp resources in Library://
Do you have a full message?
Perhaps from the "Help" -> "Last exception" ?
If the maps fail to load, there is usually a message in the
error log for MapGuide. The path for the log can be found in
serverconfig.ini
Regards, Kenneth Skovhede, GEOGRAF A/S
efrench skrev:
> Hello all,
> I’m very much new to MapGuide. After compilation from Subversion source
> failed (I’m using Fedora 9; the Makefiles generated by ./configure resulted
> in numerous errors and the like) I downloaded a copy of the Live CD, loaded
> it into a virtual machine, and copied the MapGuide installation to the
> server where I plan to run it. All the libraries I need are in place, and
> apache and mgserver appear to start up without trouble. However, I appear to
> have some permissions set wrong or something. Although the map viewer itself
> will load in all the examples, the actual maps do not load. An attempt to
> load a new Data connection in Maestro fails with the error:
>  Unable to create the resource Library://{hex sequence} Error message:
> System.Net.WebException: Error getting response stream (ReadDone2):
> ReceiveFailure -à System.Exception: at System.Net.WebConnection
> Any clue on what the problem is here? Any help would be greatly appreciated.
> Also, I notice mgserver won't start as a daemon; it only starts in
> interactive mode, but perhaps this doesn't matter so much.
> Thanks,
> Emerson French
