[mapguide-users] deployment
Zac Spitzer zac.spitzer at gmail.com
Fri Jul 31 06:00:57 EDT 2009
have u got mapguide installed on the target machine? you need to
On Fri, Jul 31, 2009 at 7:47 PM, T.kiran kumar
reddy<kiranreddy.hcu at gmail.com> wrote:
> First thanQ for ur reply now i explain the type of application we are doing
> , we convet the shp file into oracle spatial data base from that using FDO
> oracle providers we create the packages in mastro call these maps in our
> ASP.NET applications what happens is we deploy the applcation through the
> setup file entire asp.net application is working except these maps (where we
> useing the mapguie ) this is the problem ,we add
> MapGuideDotNetApi.dll,MapGuideUnmanagedApi.dll both but still maps are not
> coming other oracle tables data in our application is coming so no orcle
> problem we think  if you have solution give  reply as soon as possible its
> urgent for me.
> thanks
> T.kiran kumar reddy.
> tejaswi wrote:
>> Hi kiran,
>> Can you give in more detail on what type of application you are deploying.
>> Thanks & Regards.
>> Tejaswi.
>> T.kiran kumar reddy wrote:
>>> hi
>>> i am developing webapplication using mapguide os 2.0 , VS2005 and my
>>> system configaration is  p4 3.06hz ,1gb ram,160gb hdd .i already deployed
>>> the normal webapplication without using mapguide.is there any difference
>>> between normal web application deployment and web application with
>>> mapguide?can anyone know how to deploy the application?
>>> thanks in advance
>>> Regards
>>> kiran
> View this message in context: http://n2.nabble.com/deployment-tp3307841p3361578.html
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zac Spitzer -
http://zacster.blogspot.com
+61 405 847 168
