[mapguide-users] Symbolization ..Example
Martin Morrison martin.morrison at edsi.com
Tue Jun 2 10:54:38 EDT 2009
http://au.autodesk.com/?nd=class&session_id=1237
You talk about adding images at run-time...why?
If you have a custom image for every building, I suspect that with a sizable map you will see some performance problems as the server tries to render the map.  If you are really wanting to show a picture of an individual building, you could use a common symbol for the map then as you hover over the building show the image in a popup window.  If you are simply looking as different images for different building classes, you could theme the layers using the symbol library.
Martin
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of sathishpsk9
Sent: Tuesday, June 02, 2009 10:32 AM
To: mapguide-users at lists.osgeo.org
Subject: RE: [mapguide-users] Symbolization ..Example
Hi Martin ..........
 any url related to this ........ please do send me
Satish
View this message in context: http://n2.nabble.com/Symbolization-..Example-tp3012158p3012418.html
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
