[mapguide-users] 2.1 installation problem
Andrew DeMerchant andrew.demerchant at gemtec.ca
Thu Jun 11 10:03:02 EDT 2009
Maybe they should be disabled in the FDO right form the installer -
right now, you get errors as soon as you try to edit a layer. It's not
exactly user-friendly, right now...
Commenting those out solved the problem, by the way. Thanks!
Andrew
On 6/11/2009 10:46 AM, Zac Spitzer wrote:
> yeah, but you need the oracle client for oracle to work, same goes for
> postgres, ie libpq.dll
> On Thu, Jun 11, 2009 at 10:25 PM, Andrew
> DeMerchant<andrew.demerchant at gemtec.ca>  wrote:
>> Wouldn't a default install have installed all of the fdo's? Shouldn't they
>> all work out of the box?
>> Andrew
>> On 6/10/2009 11:35 PM, Zac Spitzer wrote:
>> try commenting out the fdo providers your not using from providers.xml
>> On Thu, Jun 11, 2009 at 5:57 AM, Andrew
>> Oh - and OCI.dll is also missing, apparently...
>> Andrew
>> On 6/10/2009 4:55 PM, Andrew DeMerchant wrote:
>> Ok - totally fresh install on Windows 2000 server...the one thing I did do
>> was install 2.0 using IIS and then removing it and installing 2.1 on Apache.
>> This was to replicate my existing conditions. I get an error saying that
>> mgserver.exe is unable to locate LIBPQ.dll. I did a search on the HD and
>> couldn't find it anywhere. This is coming up when I try to edit a data
>> source that was created and working in 2.0. From what I've seen so far, it
>> seems to run faster - but until I get a 100% working install, I'm stuck with
>> 2.0...any help?
>> Andrew
>> On 6/2/2009 11:01 AM, Andrew DeMerchant wrote:
>> Removing that line in php.ini did nothing for me - same error.....the
>> dr.watson log in my event log lists the following (from when httpd crashes):
>> "The application, , generated an application error The error occurred on
>> 06/02/2009 @ 10:38:27.130 The exception generated was c0000005 at address
>> 77FCD989 (RtlZeroHeap) "
>> I don't know apache, so interactive mode isn't something that I know how to
>> do (though I'll gladly try it with instructions). Also, this w2k
>> installation is totally up to date with WindowsUpdate.
>> Andrew
>> On 6/2/2009 10:07 AM, Jackie Ng wrote:
>> Ok I've just done a clean install on a Windows 2000 VM with a trunk build
>> installer (roughly the same as the 2.1 beta) using Apache/PHP and I have a
>> functioning server and web extensions.
>> I also got the same problems with php_MapGuideApiEnvConfig.dll in my error
>> logs.
>> So there must be some other factor at play here.
>> Have you tried running both the MapGuide Server and/or Apache interactively?
>> Please note that I also installed the Windows 2000 Update Rollup package as
>> well. I don't know if this makes a difference.
>> - Jackie
>> Jackie Ng wrote:
>> Not quite, from your observations it seems the main offender is the
>> Looking at the source-code, you'll see the GetModuleHandleEx() API I
>> mentioned being used.
>> http://trac.osgeo.org/mapguide/browser/trunk/MgDev/Web/src/PhpMapGuideApiEnvConfig/PhpMapGuideApiEnvConfig.cpp
>> Now the purpose of the php_MapGuideApiEnvConfig.dll is to resolve multiple
>> different versions of php installed on the same system.
>> If the only version of PHP you're using is the one that comes with
>> MapGuide, then you can remove the reference to
>> php_MapGuideApiEnvConfig.dll in the php.ini and see if MapGuide is
>> operational.
>> If so, then we just need to see if a Windows 2000 equivalent API exists
>> (GetModuleHandle???) that does the same thing.
>> - Jackie
>> So suddenly with MapGuide 2.1, we've lost Win2k support?? Well that
>> seriously sucks, if it's true. That means I'm stuck with 2.0 and on a
>> dead end street for the unforeseeable future. Is that correct?
>> Andrew
>> James Card wrote:
>> Aha! That explains why I was getting the same symptoms last week.
>> Perhaps we could persuade someone to add a note to the downloads page
>> at<http://mapguide.osgeo.org/download/releases/2.1.0>.
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>> Andrew DeMerchant
>> Computer Technologist
>> ph.1-877-2GEMTEC x.163
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> Fredericton, NB, Canada
>> E3C 2E6
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
>> Andrew DeMerchant
>> fax 506-453-9470
>> GEMTEC Limited
>> 191 Doak Road
>> E3C 2E6
	*Andrew DeMerchant*
*Computer Technologist*
fax 506-453-9470
/GEMTEC Limited <http://www.gemtec.ca>
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
