[mapguide-users] 2.1 - EnumerateUnmanagedData not returning anything....
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Fri Jun 12 09:05:52 EDT 2009
Mapped drives are a seriously broken MS feature, IMO.
It only works in the current user session, and you cannot activate
the authentication from anywhere else than the Explorer program.
So, first off, you need to make sure that the drives are mapped
in the MgServer impersonation role, which is "Local System" by default.
You cannot log in as "Local System", so that's a bit hard.
I have heard that you can add "net use" commands to autoexec.bat,
to have it autocreate the drives on startup in the system account,
but I never got it to work correctly, and you would be required
to have the password in clear in the file.
Regards, Kenneth Skovhede, GEOGRAF A/S
Andrew DeMerchant skrev:
> For some reason, my 2.1 installation isn't returning any of my
> external aliases with EnumerateUnmanagedData. The problem seems to be
> that my aliases point to a mapped drive. I'm not sure if this actually
> works in 2.0, but I did see a trac for this issue that said it was
> fixed back in 1.something....anyone have the same issue?
> Andrew
> 	*Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Skipped content of type multipart/related
