[mapguide-users] more 2.1 problems (GDAL this time)
Andrew DeMerchant andrew.demerchant at gemtec.ca
Fri Jun 12 15:18:17 EDT 2009
How do I get at that config.xml? I don't see it in Maestro...that's
likely the problem though. I had tried to keep my alias the same, but
thanks to a buggy handling of mapped drives, that didn't work. I then
copied things locally and moved the alias....which means that the local
path would be different. But I have gone into Maestro and edited the
path since then, to use the new alias....would it not overwrite the
config.xml with the new, correct path?
andrew
On 6/12/2009 4:09 PM, Dave Wilson wrote:
> When you "Upgraded" did you import a package to a new instance or did
> you upgrade in place?
> There is a design issue with FDO such that it doesn't know about the
> MG aliases. The paths to the data are expanded and written into the
> config.xml. If the path has changed then this will fail. For example
> if you had local data under e:\data and now it's on d:\data.
> If the path on the alias has changed this would explain why you can
> see the data in Maestro, but unless you resave the source the
> config.xml might be incorrect.
> Of course if no paths have changed (note I didn't say Alias) then
> something else is likely wrong.
> Dave
> *From:* mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] *On Behalf Of *Andrew
> DeMerchant
> *Sent:* Friday, June 12, 2009 12:53 PM
> *To:* MapGuide Users Mail List
> *Subject:* [mapguide-users] more 2.1 problems (GDAL this time)
> Sorry for the barrage of problems - but this seems to happen every
> time there's an update....I've said it before, but it would be REALLY
> nice if the upgrade process could be made without breaking everything.
> Anyway - my problem right now is with the gdal provider. I had an air
> photo layer and data source working fine in 2.0....after the upgrade
> to 2.1, that died. If I edit the existing datasource, and do a preview
> of it, I don't see any of my photos listed (the datasource points to
> an alias - which works, because I see the files listed in Maestro).
> I've tried debugging using CPL_DEBUG=ON, but that's not giving me any
> errors. I'm totally stumped as to where to go from here. I also get
> the same problem if I make a brand new datasource...
> Andrew
> *Andrew DeMerchant*
> *Computer Technologist*
> ph.1-877-2GEMTEC x.163
> fax 506-453-9470
> /GEMTEC Limited <http://www.gemtec.ca>
> /191 Doak Road
> Fredericton, NB, Canada
> E3C 2E6
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
	*Andrew DeMerchant*
fax 506-453-9470
/191 Doak Road
E3C 2E6
Skipped content of type multipart/related
