[mapguide-users] Map Guide Getting Started
mohammad abdraboh mmuslem2002 at gmail.com
Mon Jun 15 05:28:19 EDT 2009
Yes, Zac
the package directory path is correct
On Mon, Jun 15, 2009 at 11:54 AM, Zac Spitzer <zac.spitzer at gmail.com> wrote:
> is the packages directory path correct in server\bin\serverconfig.ini?
> On Mon, Jun 15, 2009 at 6:40 PM, mohammad abdraboh<mmuslem2002 at gmail.com>
> wrote:
> > Dear, Spitzer
> > Thank you for your reply
> > You are right, I have a mgp in the server\packages directory and tried to
> > import it with map admin, and the error message was
> > under the (load package) section, I received (No packages found)
> > Thank you
> > Mohammad
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Zac Spitzer -
> http://zacster.blogspot.com
> +61 405 847 168
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090615/c26e3286/attachment.html
