[mapguide-users] Enable/Disable toolbar buttons?
zolinko zolinko at freemail.hu
Mon Jun 15 10:41:30 EDT 2009
thx,
but i need it runtime.
meanwhile i've found the solution:
the enablecommand method is ok
(you can get the command object parameter from the viewerapi.commands array
by its name
-which is defined in the studio),
and then you only have to reload the tbFrame content.
thanks
sathishpsk9 wrote:
> you can also do the same through mapguide maestro... while creating a
> layout  you enable or diasable features you want ......... or you can also
> do it programatically.........once have a weblayout with you..
> weblayout.ToolBar = false ;
View this message in context: http://n2.nabble.com/Enable-Disable-toolbar-buttons--tp3080034p3080614.html
