[mapguide-users] MapGuide 2.1 Ok in Studio error Message in IE Impossible to Get Entry Point...
Kenneth Skovhede, GEOGRAF A/S ks at geograf.dk
Tue Jun 16 02:44:33 EDT 2009
The .Net api is a wrapper that calls the binary dll's.
For some reason, your application (or MapGuide) is using
the old MapGuideDotNetApi.dll and the correct unmanaged
dll's.
If it is somewhere in your application, just update MapGuideDotNetApi.dll,
and recompile the project.
If the problem is with MapGuide itself, I'm guessing that
the old dll is registered somewhere inside the GAC.
Try locating and removing it:
http://msdn.microsoft.com/en-us/library/aa559881.aspx
The correct 2.1 dll should have AssemblyVersion 1.0.0.1, where the old
one is 2.0.0.2038
(Both have fileversion 1.0.0.1)
Regards, Kenneth Skovhede, GEOGRAF A/S
Gyufi skrev:
> I don't think so, but with MapGuide I can imagine this.
> My advice to uninstall everything what belongs to MapGuide, restart the
> computer and install MapGuide again.
> When it happends with me, it was a mystery.
> I didn't find the solution.
> I just tried to give you some tip.
> Gyufi
> lunab54 wrote:
>> Directory Ok => 'C:\Program Files\OSGeo\MapGuide\Server\bin'
>> i restart iis service and mapguide service and sometimes it's running
>> again
>> but after zoom or orther it's failed.
>> when i load the 2.0 package in the 2.1 and just after i open Studio, i saw
>> that i had a lot of problem data connection invalid.
>> so i delete it and recreate again and after i can see the map
>> do you think my problem can come from the package loading ?
>> Gyufi wrote:
>>> Try to check the service (mapguide) properties.
>>> Maybe this shows a wrong directory.
>>> lunab54 wrote:
>>>> thanks, but before install MapGuide OSE 2.1, i uninstall 2.0 and delete
>>>> old folders
>>>> lunab54 wrote:
>>>>> Gyufi wrote:
>>>>>> Hi!
>>>>>> This happened with me, when I installed MapGuide 2009 and MapGuide
>>>>>> 2010 to the same server.
>>>>>> I uninstalled the MapGuide 2010.
>>>>>> Maybe you using another MapGuide API dll, which it can work.
>>>>>> If you installed more MapGuide to the same server, try to modify port
>>>>>> numbers in Server\Bin\serverconfig.ini and
>>>>>> WebServerExtensions\www\webconfig.ini, after then restart each
>>>>>> services.
>>>>>> Gyufi
>>>>>> lunab54 wrote:
>>>>>>> hi,
>>>>>>> when i display my weblayout in Studio 2009 it's ok
>>>>>>> but when i try to display it in IE i get this error message :
>>>>>>> Impossible Get Entry Point
>>>>>>> 'CSharp_MgSiteConnectionToMgGuardDisposable' in DLL
>>>>>>> 'MapGuideUnmanagedApi'.
>>>>>>> have yo an idea ?
>>>>>>> thanks
>>>>>>> Luna
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20090616/190e0048/attachment.html
